Sennheiser HD518 HD558 HD598 HD559 HD589 HD579 HD599 Support Thread
Mar 31, 2013 at 5:36 AM Post #136 of 1,140
How did you do it?? Isnt it single piece earcup? How does it sound now?
streetdragon I removed wires and driver and took sharp knife and carefully cut the grills
Sound: huge increased soundstage more width, not well defined bass slightly (but for my taste it is OK), vocals slightly better, well...and extreme look of course
I am not done yet intending to create my grills to increase bass definition...
Whoaaaaa. What did you do to them?! LOL
You removed the grill... what's that wire for?
It is the same wire which was inside of headband. I am rewiring now to make it dual entry... so this condition is just temporal.
Mar 31, 2013 at 12:51 PM Post #137 of 1,140
Hi! I have both headphones, the 558 and the 598, and I never did the foam mod to the 558. I do not belive that the 558 with the foam sounds worse than the 598; they are different, and for some music I like the 558 better; for example, I enjoy Rubber Soul (The Beatles) more while using the 558.
Yes, I agree. I'm pretty sure Sennheiser wouldn't just put a piece of foam simply to degrade the product. But I wonder why they made it removable, instead of using a material that was permanently stuck, or at least not so simple to remove?
Also, I'm pretty sure Sennheiser were aware of people doing this mod and removing the tape on their older HD555 product, so if they truly wanted to seperate and "degrade" the 55X series from the 59X series, why didn't they opt to use a different approach when manufacturing the new HD558's? I believe the foam is there for a reason, to make the sound different, not necessarily worse..
But the real/most important question is....: Did you do the foam mod?
Haha, but seriously wow you have balls to do that to your headphones.
Mar 31, 2013 at 4:23 PM Post #138 of 1,140
Yes, first time I removed only foam, It sounded better in terms of openness, and after a week around I decided to remove entire grill... I was concerned positioning of Senn logo on the grill, it is exactly in front of drivers hole, compare yourself grills of hd598 and 558
http://www.headfonia.com/wp-content/uploads/2010/09/sennheiser_hd558_598_05.jpg
So I am keeping these as a reminder
Mar 31, 2013 at 6:33 PM Post #139 of 1,140
also to add on, i found out that the place of the grill nearest to the hinge attachment is a good place to place whatever material you want, if you put duct tape there (1.0 cm x 1.5 cm piece?) you can really add a lot of bass punch while loosing not too much airyness. For me personally i placed a piece of the stock foam inside there (yes i cut it up) to increase the bass, the stock foam doesn't take away as much airyness as the ducttape though. (but at the same time doesnt add much bass either, think of it as a milder material)
i know the feeling bro, decisions,decisions..
Hinge attachment? Do you mean at the top of the grill where the headband attaches? I wonder if i could put some stuff on the outside? lmao :p
Mar 31, 2013 at 6:37 PM Post #140 of 1,140
I think it is there to degrade it. I mean look at how flashy the 598's are. It also comes with a leather headband and it is suppose to be more comfortable. I think they tried to pull a fast one and i didn't fall for it considering both 558 and 598 have the same drivers... just different housing. I've never tried the 598's before but i really doubt they sound better. People that say it sounds better are victims of the old placebo effect... i could be wrong though.
Also, how do you quote 2 people? I didn't want to make 2 posts :frowning2:
Mar 31, 2013 at 9:01 PM Post #141 of 1,140
These mods are invasive! When I took the foam out of mine I tried them on without the pads or those cheesecloth looking things. Just the drivers over my ears.
Apr 1, 2013 at 3:29 AM Post #142 of 1,140
Well what i actually meant by that is the placement in the picture: (if that's what you meant then, good then haha)
and well you could stick stuff outside, it just won't behave very well with the cloth material outside and it won't look pretty too...
Apr 1, 2013 at 7:59 AM Post #143 of 1,140
I read somewhere on here that you could remove the lining on these headphones to open them up even more. I've already did the mod, so I'm wondering if its possible to open these up even more? Without the extremeness of the above post.  I still have yet to find a suitable amp, or better yet is it even needed with a standard laptop sound card.
Head-Fi has taken over my life.
Apr 1, 2013 at 10:43 AM Post #144 of 1,140
Well i suppose you could, it might be ugly if the cloth doesn't come out completely, but mostly it is non reversable.
C-entrance DACport is actually a good choice for these.
Apr 1, 2013 at 10:50 AM Post #145 of 1,140
Head-Fi has taken over my life. :darthsmile:
These respond a bit to a better amp, although not to the extent of DT880/990/K70x/HD6x0. Most aftermarket entry-level amps will suffice.
Apr 1, 2013 at 11:03 AM Post #146 of 1,140
Just wondering do you mean entry level as about E6 price? or E17 kind? or more (which is still little compared to the big woo amps)
Apr 1, 2013 at 1:22 PM Post #147 of 1,140
E5/6/7 is LOL
myunclesnephew probably meant desktop units since he mentioned a "semi-desktop" unit.  =]
Apr 1, 2013 at 7:32 PM Post #148 of 1,140
That thing looks sweet...my gosh
 A bit out of my price range though.
I removed the lining this evening and I must say it seems to made sound crispy. It maybe a placebo effect but the highs seems stronger, not fatiguing.
Apr 1, 2013 at 7:49 PM Post #149 of 1,140
darn now i'm tempted, i'm too scared to try it out though
Apr 1, 2013 at 8:06 PM Post #150 of 1,140
Wouldn't dust get in there now though? If it wasn't for dust i'd mod the hell out of mine lmao
Hey, could you post a picture so we can see what it looks like? pleeeeeeeeeeeeeease? :)
