Ok what i am going to share is a mod for senn hd 449 which will make them create more deep and controlled bass, audeze lcd x sort of midrange and bower and wilkins p5 sort of treble(extended and airy) with huge sound stage and image
Material needed-
1.dynamat extreme(dampmat exceed dor even more controll)
2.Acoustipack extra sheet 3 layer dampening
3.Teased absorbent cotton for medical purpose
Procedure
1. Push one side of earpad till it get snap open(dont apply to much pressure at once)
2. You will see a foam surrounded driver.
3. Try to feel screw beneath the foam and tear that small part and open it up gently as wire are fragile
4. U will see a mesh tape over 3 vents
Remove the tape so that the driver can breathe properly.
But then this will create more resonance on body of speaker.... so take dynamat and paste it at the back of the body so the driver dont vibrate heavily
5. Paste acoustipack inside the cup(cut into the shape of cup)
7. Fill it with teased cotton. Dont add to much of cotton.
8. Close the set and remove the front foam and replace with acousttipack sheet(same cut design)
9. Replace the earpad and enjoy the senn hd 449 rebirth or mid forward senn hd650
