ruinedx
- Sep 11, 2016
HD600 soundstage is VERY amp dependant. Pair it with a SS amp like the Schiit Jotunheim which has an inherently narrow and compressed soundstage and the HD600 produces a claustrophobic "inside the head" image. However, pair it with a good tube amp, or even a hybrid-tube amp like the Schiit Mjolnir 2, and the HD600 is transformed into a very open-sounding headphone with amazing space, decay and separation between instruments. The difference is pretty amazing. HD600 paired with a Schiit Mjolnir 2 fitted with Siemens PCC88 (1963) tubes or similar, plus a bit of low-end bass EQ boost, comes pretty close to an end-game combo IMO.
The problem is, if the headphones are *that* amp dependent to sound ideal then I consider it a serious weakness of the headphone. The HD800 has the same problem, extremely gear dependent. If I buy multiple $1000+ HPA/DAC units plus ones that cost less than that and still can't get a sound I'm even remotely happy with then I'm going to blame the headphone, not the gear. Maybe HD600 can have a good soundstage with just the right gear, and maybe HD800 can not have ear-piercing treble with just the right gear, but overall these seem to be weaknesses of these headphones that you can compensate for with very specific gear. The HD700 is a little picky, but for the most part it sounds great on most gear I've tried (even sounds excellent on LG smartphones that have the builtin headphone amp + ess sabre DACs, which is an impressive feat) - and HD820 seems quite gear agnostic so far as well - both of which I will therefore say are better headphone designs since they sound fantastic out of box to my ear on a wide variety of equipment instead of needing to be mated to a narrow selection of equipment (or require substantial EQ, or require user modification, etc) to sound ideal.
For the four headphones I owned that were on topic for this discussion - I A/B compared the HD700 to the HD600 on multiple HPA/DACs and the HD700 blew away the HD600's soundstage on all of the gear I tried. I also A/B compared the HD800 to the HD700 and A/B compared the HD820 to the HD700 again on same equip - both HD8xx models blew away the HD700's soundstage and from memory (was unable to A/B) the HD800 beat the HD820's soundstage - but the HD800 was far too aggressive in the treble to use in the long term (i found it physically painful) and was too lean in the bass, which HD820 solved on both fronts in my case and was worth sacrificing a bit of soundstage for (note, despite this the HD820 soundstage substantially beats the HD700's already-impressive soundstage from my testing). So I have settled on for music the HD700 + HD820 as my "go to" pair to use - selecting each depending on the use case - as soundstage is one of my top needs, if not top need, in selecting a headphone.
