Sennheiser HD 598 Impressions Thread
Discussion in 'Headphones (full-size)' started by Headstar, Feb 22, 2011.
326 327 328 329 330 331 332 333 334 335
337 338 339 340 341 342 343 344 345 346
  1. JMcNeill
    Just ordered my V-MODA BoomPro Mic today.. it'll take 1-2 weeks to get here so i decided to jerry rig my own lil modmic together. Took the mic off an old Logitech headset I had laying around and taped her up.. she aint pretty but she works! [​IMG] lol. http://imgur.com/a/Revqg
  2. DopeMusic
    OK, now that I had the Sennheiser 598, I'm going to take my first portable DAC / AMP, my choice is between these three options:
    - Schiit Fulla
    - FiiO E07K
    - FiiO E17K
    What do you reccomend?And why?
    And what I have to buy cables for use outside? Counting that use it with an iPod Classic (160GB)
    Thanks to those who have the patience to answer!
  3. Sam21
    if you can get the E17 (not E17K) for a good price then I would go for it...it has opt/coax/usb in. it has line in/out and it has a nice EQ.
  4. DopeMusic
    Unfortunately on amazon (Italy) there is only the E17K at 150 €, the E17 costs 250 €..I can't spend more than 150€
  5. Sam21
    if you want it to be portable check out also the creative E5.
    For desktop use AudioEngine D1 is a good DAC/AMP combo...you could also buy separate AMP and DAC...
  6. DopeMusic
    What are the differences betwenn:
    - FiiO E07K
    - FiiO E17K
    The FiiO E17K now is 100$ on Massdrop!
  7. Sam21
    here you can compare them :
    http://www.fiio.net/en/products/38/comparisons
  8. DopeMusic
    What would you recommend if I were to buy a DAC and a separate AMP?
    I never had neither one nor the other, and do not know what could have brought better sound quality. Listening to music from an old laptop Compaq Presario CQ60! I really have no idea what to buy!
  9. amigomatt
    I would recommend the HRT Microstreamer. It's compact, amazing sound quality and you can use it to upgrade the audio of your PC/Mac or Android phone. It sounds phenomenal and has plenty of power to drive all but the most demanding headphones. You can also use it as a DAC alone through the direct line out into a beefier amp if you so wish in the future. It truly is an amazing little box.
  10. DopeMusic
    Something less expensive? I would not spend more than 100-110 €! The HRT is 181€ now on Amazon Italy
  11. amigomatt
    Have you tried used on ebay?
  12. XERO1
    A new all-black HD 598SE is now available on Amazon for $199!
    It also includes a short 1.2m cable with a 3.5mm connector (thank you!).
    http://www.amazon.com/Sennheiser-HD-598-Over-Ear-Headphones/dp/B0126HISOO
  13. Bansaku
    DAMN them cans are SEXY!!!!
    [​IMG]
  14. amigomatt
    Hey, are they the same in terms of sound?  Just cosmetically different?
  15. XERO1
    Unknown.  But they probably have the same SQ as the regular HD 598.
