Sennheiser HD 598 Impressions Thread
post-11101191
Post #4,171 of 7,528
amigomatt
Manchester, UK
Manchester, UK
Hello,
I have just recently bought the HD598 and did not know there was a twist-and-lock mechanism for the cable.  I yanked at it hard a couple of times before I gave up and searched up that it had a twist-and-lock.  The lock still seems to be intact in the headphone and was wondering how I would know if I damaged the headphones (everything appears to be fine and still working) as well as the potential areas that could be damaged from a stupid act like this.
Thanks in advance !
It sounds like you're ok. I remember trying to suss that out when I first got them. I just didn't dare pull past a certain amount of force. They're pretty sturdily built headphones and i imagine the cable would give way before the socket, which is chrome. I wouldn't advise testing that theory out though!
post-11101255
Post #4,172 of 7,528
Headstar
As long as they work, cable is intact, and nothing seems to move inside, it seems everything is fine. So, don't worry about. :)
post-11101292
Post #4,173 of 7,528
ruthieandjohn
Stumbling towards enlightenment
(Formerly known as kayandjohn.)
Poulsbo, WA, USA
Poulsbo, WA, USA
Hello,
Thanks in advance !
I had a similar problem. If there is damage, it seems to occur to the cable connector, not to the headphone receptacle. This is good, because you can replace the cable more easily.
But the simple answer is...mid it SOUNDS ok, then it IS ok. Wiggle the connections... If no static, you are fine.
post-11103775
Post #4,174 of 7,528
nVme
thank you for all the helpful replies! :)
no static and everything appears to be the same besides my paranoia.  I think i got lucky haha
post-11104615
Post #4,175 of 7,528
arthasss
Hi guys
I am considering buying this headphones and some dac/amp
I am looking at the fiio e7k ,or should I just buy a dac since this thing is not hard to drive
And is there any good desktop amp/dac at the 100$ since I don't need portable one
Thanks
post-11104727
Post #4,176 of 7,528
BillsonChang007
Johor, Malaysia
Johor, Malaysia
Hi guys
Thanks
FiiO E7K is a amp/DAC itself already. Look into the E10K as well :)
post-11104766
Post #4,177 of 7,528
arthasss
Fiio 10k is looking very good
I heard that Fiio e11k is a little brighter, is the fiio e10k a little warm, is there any other difference, what would suit better for 598
Thanks:D
post-11104982
Post #4,178 of 7,528
BillsonChang007
Johor, Malaysia
Johor, Malaysia
Thanks:D
FYI, E11k is just an amplifier. E10K is a DAC/amp combo.
The job of a DAC is to convert our digital files into analog while amplifier is to power a headphone.
If you are looking for a DAC/amp combo, you are better off with E10K :)
Billson
post-11105000
Post #4,179 of 7,528
blse59
I'm using a E10K. It's great! How much more would I have to pay to get noticeably better sound? These are clean and noiseless already.
post-11105281
Post #4,180 of 7,528
VXAce
Depends on your definition of "better".
post-11105578
Post #4,181 of 7,528
arthasss
Opp ,didn't see that ee11is only a amp:D
I can get e07k and e10k for the same price, what would you guys recommend for these
Thanks:D
post-11105680
Post #4,182 of 7,528
BillsonChang007
Johor, Malaysia
Johor, Malaysia
Thanks:D
Deskrop (E10K) or portable (E07K) :wink:
post-11106080
Post #4,183 of 7,528
Arsis
post-11110259
Post #4,184 of 7,528
Dinerenblanc
Well, my Amazon purchase finally came in the mail today, and I must say I'm quite pleased with these.
 I never really liked how full sized headphones felt when worn, but these are so comfortable I'm willing to give them a pass. Not bad at all for my first pair of cans.
post-11111097
Post #4,185 of 7,528
nihontoman
nice. mine also arrived at mu U.S. shippin agent address but will have to wait to get them another week... I hope it is worth the wait though.
could you comment on sound ? as a first pair of cans for you, it is interesting to know what your thoughts are on them in general...
