Sennheiser HD 598 Impressions Thread
post-9693607
Post #2,671 of 7,528
tannerbnd
Aka: Tannerbnd24
Aka: rivers1724
Aka: rivers17
i swear, these cans amaze me every time I wear them....i'm ready to sell all my other cans, and just roll with these
post-9693837
Post #2,673 of 7,528
vsg28
Got my eBay cable today and I have to say I am pretty impressed by the whole thing- build quality and sound quality wise.
post-9694352
Post #2,674 of 7,528
kimvictor
Just mentioning this, but HD598 goes really well with AK100 unmodded. Very smooth with best detail I've heard from HD598.
post-9694927
Post #2,675 of 7,528
kenman345
It sounds quite awesome with my RWAK100 as well. I'm really happy with the combination though I usually use a desktop amp with the two as I normally keep the HD 598's always plugged into my Maverick Audio D1+
post-9696865
Post #2,676 of 7,528
Metsuki
Does anyone know where I can get a replacement for the headband cushion?
post-9702286
Post #2,678 of 7,528
MegaMushroom
Japan
Japan
Gonna have to echo the post above me.  Contacting Sennheiser is likely going to be the easiest way.  Granted you can get a 558 head band cushion from Amazon.  If you don't mind clashing colors that is something to consider.
post-9702750
Post #2,679 of 7,528
Metsuki
I kind of wanted to avoid contacting sennheiser since I assume that it's going to take a while for them to replace it.
Could you post a link? I can only find the ear pads.
post-9702782
Post #2,680 of 7,528
Headstar
I think it's a good idea to contact Sennheiser. Their customer services proved to be at high level. Some people received even brand new pairs when sending one for repair. Or they received HD 598s when they sent old HD 595s for repair. (as mentioned in reviews on amazon.com)
Now i'm not saying it will happen to anyone. Might depend on the severity of the problem. But you never know without trying. I've got very fast responses when i had to replace my broken HD 598 some two years ago.
post-9702876
Post #2,681 of 7,528
vsg28
Sennheiser USA has excellent support and turn around time, so if you are from the US then they are definitely your best bet. More often than not, they will just send you a brand new set.
post-9702903
Post #2,682 of 7,528
Schonen
I tried to source new ear pad replacements form my beyer 990pro and on amazon.ca this place wanted $70.00. Nope.
post-9703183
Post #2,683 of 7,528
Metsuki
I'm from Europe. I'm not sure they'll cover it since it's the usual wear and tear, nothing's actually defective.
post-9707914
Post #2,684 of 7,528
exquisite
Hi all,
Got this headphones 2 days ago (new, sealed box , from amazon) and noticed a construction difference between the 2 cups.
Can´t figure out yet if the sound is affected in anyway (as they are still burning in) but the lower part of the left cup has
some more of the inside mesh "glued" to the background than the right one. Took some macros where it is clearly seen.
Has any of you noticed the same on their cans? Could it be a manufacturing flaw? Some quality control issues? What do you think?
I would return them in the 30days period if I need to, just wanted to check if anybody else has the same problem.
Thanks in advance for your input.
Left cup:
Right cup :
Reactions: GoodBoy
post-9707951
Post #2,685 of 7,528
KevinMHC
Anyone have experience with the Philips X1?  How does it compare to the HD598?  I have a pair of HD 598, while it is crisp and clear, I find it distant and un-engaging.  Not sure if its just me.
