Sennheiser HD 598 and what sound card?
Discussion in 'Headphones (full-size)' started by headshot, Sep 28, 2012.
  1. headshot
    Hey folks. Im hoping someone can advice me on this matter. I got these great headphones thanks to mad lust envy brilliant thread but now I need a PCIE sound card to go along with these great headphones
    Ill be using the headphones mostly for gaming and music
    Im not sure on budget, I know I want the best out of the headphones but iv already spend alot on these headphones so no crazy money on a sound card if possible please
  2. KCxSmacker
    Well I find to an extent you get what you pay for with sound cards. I'm assuming you are going to be mainly gaming, rather then music. Saying this I would suggest the Creative Titanium HD. you can get it for anywhere from 100-139.99 depend on the time and place you buy it. Another option if you are big into music is the Asus Xonar Essence st/stx.
    Hope this helps,
    if you can list a budget,
    cheers
  3. headshot
    thanks for the reply
    Yes ill be gaming mostly. Yes Titanium HD is a superb card but im not sure is it worth spending the extra for it. May I ask what do you think of the Asus Xonar D2X?
    my budget is around 100
  4. NamelessPFG
    If you want to keep costs down, here's a $45 X-Fi Titanium.
    Analog sound quality obviously isn't as good as the Titanium HD, but it is under half the price and still has all the gaming features while still sounding reasonably good.
    You can get improved sound quality later if you're willing to buy a DAC with S/PDIF input.
  5. fabio-fi
    Xonars are pretty good with music, but if gaming is a priority you'll like the X-fi.
  6. headshot
    tell me more
    thanks for the input. Truth be told I had the x-fi once and loved them, But I built a new computer with 2x 670s and there wasnt room for it but now iv learned away around this problem using a PCI-E Express Flexible Cable Extender Card
    Its looking like ill be rebuying the card. Feel like an idiot thinking my mobo sound would do ugh
  7. NamelessPFG
    If you go into the X-Fi's settings, you'll find a "Play Stereo Mix using Digital Output" checkbox under one of the settings tabs. (Which tab it is depends on whether you use the Audio Control Panel or the Console Launcher. The former has it under SPDIF I/O, the latter under Digital I/O.)
    Once you enable that, you get the same two channels through S/PDIF that you do through analog.
    As for which DAC to use, I have no specific recommendations since they all get on the expensive side (read: over twice the price of the X-Fi Titanium HD). I have heard good things about the Cambridge DacMagic and the PS Audio Digital Link series, though.
  8. PurpleAngel Contributor
    What make and model motherboard is it?
  9. headshot
    Asrock z77 extreme 4
  10. headshot
    Just to say im a very happy owner of HD598's and creative titanium HD.
    Im wondering what is the best method method of connecting them to the sound card? Should I just use sound cards headphone socket or is there somthing better?
