Sennheiser HD-595 good for starters?
Feb 14, 2009 at 4:14 PM Post #16 of 33
NikZ
IEMs is probably more suitable than full-sized. It's troublesome to carry a pair of big and expensive headphones around while you can just put iems in your pocket. Noise isolation and leakage are better too.
Feb 14, 2009 at 4:28 PM Post #17 of 33
vvanrij
Yup, IEM's or ultrasones I would suggest.
Feb 14, 2009 at 4:33 PM Post #18 of 33
MRSHUTHEHELLUP
iems make my ears itch after about an hour... no can do on those.
sooo... y'all think those denons will produce too much bass for metal. i know it would sound killer for movies. i watch mostly horror and war flicks
Feb 14, 2009 at 5:01 PM Post #20 of 33
vvanrij
But they make noise...
Feb 14, 2009 at 5:03 PM Post #21 of 33
scytheavatar
And can I ask what IEMs have you tried before? IEMs vary greatly in terms of comfort, so I don't think it's fair for you to think that all IEMs will make your ears itch.
Anyway the Denons's bass will certainly be a bit too boomy for many metal songs, but on the flip side you get some awesome head rattling action. Just stay away from the HD595, it sucks.
Feb 14, 2009 at 5:23 PM Post #23 of 33
scytheavatar
It might be a possible option. Its bass is top notch and while I dislike the HFI 780 mids many people like them for metal (not me). But don't expect to be able to wear it for hours, its comfort isn't that much better than the Grados.
Feb 14, 2009 at 5:53 PM Post #24 of 33
ngsm13
Originally Posted by QQQ /img/forum/go_quote.gif
Better buy HD 555, same headphone as hd 595 after removing some foam from inside.
INdeed, do that and replace with equal length cable runs and you're good to go.
nG
Feb 14, 2009 at 6:00 PM Post #25 of 33
vvanrij
555 are open headphones right? Like I said before, they make loads of noise for his fellow busriders.
Feb 14, 2009 at 6:01 PM Post #26 of 33
MRSHUTHEHELLUP
nG
this ngdm13 guy is a car audio guru too... what's up buddy? remember beelzebub? hahahahahaha
Feb 14, 2009 at 7:47 PM Post #29 of 33
csommers
If you really don't want people around you to hear what you are listening to then IMHO pick up some IEMs. I used to have HD595s and they bleed sound like crazy, but thats the nature of that type of headphones.
Feb 14, 2009 at 8:11 PM Post #30 of 33
ZarakiSan
Reading the thread, I would say denons are your best bet. Get the D2000's, and you could upgrade them later if you like
