Sennheiser 555 or Alessandro MS1? Upgrading my Senn 497!
Jun 22, 2007 at 9:44 AM Post #16 of 40
I'm not really sure why you guys are comparing the 555s with the 480s. Many agree that it's more forward and less veiled than other Senns.
Jun 22, 2007 at 9:57 AM Post #17 of 40
Originally Posted by shampoosuicide /img/forum/go_quote.gif
Just to clarify, all my music is ripped at at least 192kbps, only a small portion at 128kbps. It is not possible to change the components (soundcard) of an iMac.
Can anyone fill me in on the performance of the MS1 at electronica, hip-hop, dance, etc.?
The MS-1 is generally regarded as fairly competent with those genres, though perhaps not if you want accentuated bass.
Yes, you can't change your internal soundcard, but you can easily work around it, for instance with a USB dac or external soundcard. There are options under $100 that could really change your listening experience, and open up the capabilities of the new headphones you're going to buy.
? Are you talking about this thread? What's a 480?
edit-- you think he meant a 485, gazwsx? But nobody mentioned one of those either. Maybe he meant SR-80? I think it's just confusion.
by the way, shampoo, I'd recommend getting an MS-1 over an HD555 without question, but really think of getting an external sound card as well. I see a used bithead in the fs forum for $125, add in a pair of MB QP55x from that ebay clearance house that has them, and you're barely over $150, with a system to humble an HD555 straight out of your mac.
Jun 22, 2007 at 11:08 AM Post #18 of 40
Because the next up after the 485's (I assume that's what you mean) is the 555. Of course you must skip the 515 because it sounds like it's $20.
Jun 22, 2007 at 11:39 AM Post #19 of 40
I can vouch for HD555 - decent all rounder specially considering you're not using an amp. But I have the feeling that most people will recommend the MS-1 over the HD555 especially if rock is your favourite.
Jun 22, 2007 at 11:49 AM Post #20 of 40
Originally Posted by Bozz_Keren /img/forum/go_quote.gif
does ms-1 comes with comfy? because i've never wear one, does it feels like Grados?
Yup; and yup!
Yup; they come with comfies alright. And they feel exactly like Grados...cause the ARE Grados! They're just tuned to sound a little differently than the other Grados.
Thankfully, pads are relatively inexpensive and can easily be swapped around for just the right combination of comfort andperformance!
Jun 22, 2007 at 1:19 PM Post #21 of 40
i'm in crossroad wether to buy sr80 or ms-1, but the latter kinda hard to order, i'm not in us, but i'm so interested in ms-1, btw does ms-1 sounds much better than sr80? if it's just slightly better i think i'll go with sr80
Jun 22, 2007 at 1:28 PM Post #22 of 40
They're the same price at $100.
Jun 22, 2007 at 3:18 PM Post #24 of 40
sr80 in my country is around $98, ms-1 is $99, pretty much the same
if i like rock and jazz, which should i choose btw
Jun 22, 2007 at 3:33 PM Post #25 of 40
From posts I've read, most prefer the sound of MS1s over the SR80s. They say that 80's treble is a little too harsh.
Jun 22, 2007 at 3:56 PM Post #27 of 40
Thank you for the suggestions! I do have a budget. However, I will definitely look into getting an external sound card. I'm quite ignorant about this whole sound card/amp business, but isn't the Bithead an amp? Are there any sound cards you would recommend that I could look into?
Jun 22, 2007 at 5:17 PM Post #28 of 40
The bithead is an amp, but it also has a built in DAC (digital-analog converter). This is exactly what a sound card does (DACing and amplifying) (and why your conputer will recognize it as a sound card). It attaches to your computer through the USB connection.
As such, any USB DAC will work as an external soundcard for pretty much any computer, and there are several at many prices. Search the forums and you will find a ton of information.
I can't weigh in on the ms1 vs 555 since I haven't heard either one, sorry.
Jun 22, 2007 at 5:45 PM Post #29 of 40
I put about 300 hours on the HD555 and only 3 hours or so with the MS1, but:
- MS1 is massively better for rock. Guitars etc sound synthetic to me on 555s.
- 555 probably better for dance/electronica
- MS1 are pretty comfortable, but you can wear 555 for 12 hours a day!
It's important to remember that both are different and many people own both, so I wouldn't worry too much about making the 'right' decision here. I'd bet you would be very happy with either of them, and who knows, in a few months' time you might have another $100 to spare for the other set.
Jun 23, 2007 at 4:20 AM Post #30 of 40
hmm i think i'll go with ms-1, 2morrow i'm gonna test both at my supplier shop
thanks anyway
