fleasbaby
Member of the Trade: Wabi Sabi Headphones
- Jul 8, 2011
...did a collab with @cCasper TFG and this was what came of it:
They are Marblewood (hideously tough, fibrous stuff...my chisels took a bit of a beating) cut similarly to a GS1000 style Grado cup with a wider pad lip to accommodate Beyer pads. Cables were by cCasper TFG, and are removable (mini-XLR). One is terminated for balanced operation, the other to a 1/4 inch plug.
SennGrado build.
The sound seems to be uneven....seems to be more sound coming from the left side.
@DavidA actually the specific foam disk (Superlux HD660) fleasbaby had put in actually had very minimal effect. it had a very slight mellowing effect for the extreme ranges of the treble, without removing the sparkle. Without the disk the driver is just very very slightly harsh, and with it that slight harshness is gone. I had tried another foam disk that came with the replacement pads for the DT880s and that dull / muddled things significantly.
I should also add that i had gotten the oem black velour dt880 ear pads (not the disks, the pads) and they sounded denser and more muffled with a midbass hump, while the stock dt880 silver velour pads that i have on right retains the sparkle and mids and allows (perhaps even refines?) the bass to do its thing.
ah, well its like a very thin piece, the one from the superlux. its not quite totally sheer but you can kinda see through it. the beyer dt880 disks tho are much thicker
nice~ actually the disk i have is probably not not as thin as the silk organza you posted.
