Senn HD280 Help
Jul 9, 2008 at 3:16 AM Thread Starter Post #1 of 4
pplinux
The cable got screwed up and now I only hear the left side.
I want to replace the wire. I dont want silver (unless you think it would help in such low-end headphones).
I know sennheiser offers a replacement cable but its $30
When you open the left can you can see 4 small wires that are soldered into a smalll pcb. Theese are the ones that go through to the mini jack
I can solder so I just need to know where can I get it and what kind of wire is that so i can buy it.
I dont know if this is a stupid question or not because I dont know much about audio cables but any help is good
Thank You
Jul 9, 2008 at 4:20 AM Post #3 of 4
those 4 pins can actually be unplugged from the PCB, i recables mine a while back with canare mini mic cable, i forget the model, i sold the headphones
are u replacing the main cable or the smaill wires inside that go to the drivers?
Jul 9, 2008 at 3:40 PM Post #4 of 4
MisterX you are correct. it goes to a plug that plugs into the pcb. I was more concerned with the "type" of cable. is the there a specific gauge or something. any specifics that I need to know?
I am new to audio so that is why I am asking
