thaitrong
Thank you for your reply! sorry I'm new to audio can you explain what the phono input is for and The 5 pin DIN sockets are for inputs 2-6?! thank you very much
What did you replace it with?I've sold my yggdrasil v2 usb 5. Sadly it wasn't the best experience.
Sound quality was impressive, but the general usability wasn't. It often dropped signals on Windows ( never on raspberry ), often I had to switch completely off and wait to watch it on again. Another thing was the absence of any kind of remote controller, so when I had to switch input, I had to get up.
The only thing I liked about it was the 2 rca outputs. Very rare and useful for people like me with a lot of headphone amps.
No more words about dimensions, everyone knows how big it is.
Nothing special, I made blind test with switches and honestly I don't find differences between a cheap good measuring dac and expensive good measuring dac. So, I'm sticking with a topping d90, a fiio k9 pro and a marantz hd-dac1 on the speaker system, just because I like the form factor.What did you replace it with?
Aes. That's what I use with my Hermes ddcFor various “wire logistics” reasons but primarily because I’m running an Mscaler as an upstream DDC, I cannot use usb input into my Yggy LIM. What is preferred “second best” choice between optical, BNC, or coaxial? Thank you for your input.
I would say BNC->COAX->optical, IMHO, YMMVFor various “wire logistics” reasons but primarily because I’m running an Mscaler as an upstream DDC, I cannot use usb input into my Yggy LIM. What is preferred “second best” choice between optical, BNC, or coaxial? Thank you for your input.
In some of Mike Moffat’s posts about digital, I recall him stating that many digital devices, including Yggy, need to be ”burped“ occasionally, with no technical explanation. I do this with my server, uDO interface, and Yggy infrequently.Hey guys, I've owned my Yggdrasil since 2017, bought it as first gen from Schiitr, and then later upgraded with gen5 USB, and then to GS and then a LIM. Throughout the years, there had been a curious issue with it. I know everyone recommended not to switch off Yggdrasil, but every now and then, the sound becomes "muted", dynamics lost and the highs seems to be cut off. At this point, the only solution is to reboot it, turning it off for about 10 sec and restart the DAC to get back to the "normal" music.
Just wondering what the root cause is and will there ever be a solution to this?
I got a similar issue once or twice a while back (also early model) but I added a power conditioner and it has not happened since. It was like it was stuck in a loop and needed to "clear cache" or clear buffers, in my case. I have only gone up tp A2 and gen5 USB, so no GS and LIM, though.Hey guys, I've owned my Yggdrasil since 2017, bought it as first gen from Schiitr, and then later upgraded with gen5 USB, and then to GS and then a LIM. Throughout the years, there had been a curious issue with it. I know everyone recommended not to switch off Yggdrasil, but every now and then, the sound becomes "muted", dynamics lost and the highs seems to be cut off. At this point, the only solution is to reboot it, turning it off for about 10 sec and restart the DAC to get back to the "normal" music.
I wonder if it's got to do with a rumored grounding change because you mentioned that it's fixed by a power conditioner. Does anyone have details in what exactly was the grounding change?I got a similar issue once or twice a while back (also early model) but I added a power conditioner and it has not happened since. It was like it was stuck in a loop and needed to "clear cache" or clear buffers, in my case. I have only gone up tp A2 and gen5 USB, so no GS and LIM, though.
I was fortunate enough to find a Yggdrasil A2 w/Unison second hand in excellent condition. It arrived only today so I have it on the alternate desk plugged in and warming up and as such have only done some casual listening. I'm hoping that by the weekend it will be sufficiently warmed up so that I can get a decent feel for it with the rest of my setup.The OG is what was previously called A2/Unison, correct? - This is the Yggdrasil I am interested in. I don't see many examples on the pre-owned market, is it outrageous to consider ordering one new from Schiit this day in age?
If both were good measuring DACs with similar topologies, why would you expect to hear a difference tho? I agree, I would go less expensive in that case because I also have a really hard time noticing any significant difference between my delta sigma DACs... they all sound fine.Nothing special, I made blind test with switches and honestly I don't find differences between a cheap good measuring dac and expensive good measuring dac. So, I'm sticking with a topping d90, a fiio k9 pro and a marantz hd-dac1 on the speaker system, just because I like the form factor.
Sorry to say that, if anyone is happy with new magical things listened through an expensive r2r\multibit dac, good for him
