cc :
@Jason Stoddard
Hello Yggdrasil phriends! It has been a while since I've posted. Believe it or not, I'm currently involved in a local (Long Island, NY) "DAC shootout" where I'm installing my Yggdrasil (version 2, B serial number, Gen 5 USB card) into other folks systems so as to compare,
and in some cases folks have shown interest in buying the Yggy! To this end, I ran into a strange problem yesterday. Can someone please answer the following? BTW, I have also emailed Schiit (at their
info@schiit.com address) but have yet to receive their reply.
I hooked up the Yggy dac to a system that has an mhdt orchid dac.
The yggy recognizes a signal from an Innuos server, model zen mk3 streamer, but there's no output (sound). It's being fed through USB cable and I'm attempting to output via SE. There are no other options in order to do an apples to apples comparison as the amp here is a Pas INT25 and the mk3 is only USB. We rebooted equipment and changed server settings, including but not limited to setting the server to transcode DSD output to FLAC and set the PCM Sampling Rate Limit to 96kHz. Still no output.
Upon my reading the specs of zen mk3 I note it has only "digital USB 2.0 output". When I google the spec on digital USB 2.0 output, I find there are three different types of implementations, two of which are
not PCM. I realize that the Yggy only plays PCM. Could this be the issue? Can anyone offer any insight and/or corroborate my thinking about the mk3 not outputting PCM? Note that if this is the case (not outputting PCM), the Yggy's sample rate indicator lights were on and did sense a signal, matching the sample rate that the server indicated. But again, there simply was no sound to be heard.
Thank you all in advance.
Hal
