Schiit Valhalla Tube Rolling thread.
Jul 27, 2012 at 11:17 PM Post #16 of 1,988
paradoxper
Jul 28, 2012 at 12:26 AM Post #18 of 1,988
schaaf
All my music with the exception of maybe 20% of it is lossless. It's running right into the amp. I dont have a DAC yet.
Yes. It sounds better thru the amp, but straight out of the Mac they're not as bright. Just more... muffled and less powerful/impactful.
I'll stick with it, but I hope they start to mellow out.
S-
Jul 28, 2012 at 12:34 AM Post #19 of 1,988
paradoxper
S-
And with what headphones are you using?
Jul 28, 2012 at 1:19 AM Post #21 of 1,988
Mr.Tom
S-
The D2A chip in the mac is not high end, or even close. I suspect what your hearing is amplified noise from the mac.
One thing I've learned about the Valhalla(maybe all OTL amps), is that it reproduces everything. I only figured that out when I went from a Zero dac to the Bifrost dac, as some of the harshness I was hearing was the Zero dac.
Jul 28, 2012 at 1:27 AM Post #22 of 1,988
paradoxper
The 650's are pretty laid back, so I am going to say that's not the problem. Hopefully you've got all your music properly
converted to FLAC/ALAC. Which would just leave one big problem, you don't have a DAC.
It's most likely just your amp amplifying garbage from you Mac digital out. Get a DAC and this should alleviate the pain.
Jul 28, 2012 at 1:53 AM Post #23 of 1,988
Mr.Tom
It's not even going via digital out. He's running out of the line level to the Valhalla. That means the audio is being amplified to line level by a $.05 op-amp, and a handfull of other cheap parts.
Jul 28, 2012 at 2:03 AM Post #24 of 1,988
paradoxper
Is he using a 3.5mm stereo male to 2RCA male?
Jul 28, 2012 at 12:07 PM Post #26 of 1,988
Mr.Tom
Yes. As I don't yet have a DAC, it's all there is to do.
And all but 20% or so of my music is lossless, yes.
I'm working on getting a DAC, but it might be a couple if weeks.
You may want to look at something like a DAC Magic, as there said to sound a little warmer than a Bifrost. And I often see used for half of new.
Jul 28, 2012 at 1:01 PM Post #27 of 1,988
paradoxper
I'd go with either ODAC or Bifrost. Just based on hearing everything over and under your potential budget. Both those DACs are a very good value.
DAC Magic isn't that great, IMO. But give us a budget to better specify options for you.
Jul 28, 2012 at 8:38 PM Post #29 of 1,988
paradoxper
Sorry - yeah it's going to be a bifrost.
S-
Should be quite a few hitting the F/S forum in August, er, maybe early September. haha
Jul 30, 2012 at 12:21 PM Post #30 of 1,988
Mr.Tom
Back to Rolling! So I was very please with the 6n1p, as it gave the Valhalla a very HiEnd SS sound, also keeping the tube sound in the upper bass/lower midrange. But I was finding a slight fatigue after 6 hours of listening.
And I could not even take the Dead Kennedy's for 5 minutes. So I dug around and found some 6n23p. These tubes remove the extreme detail of the 6n1p, also replacing the dry with a wet warm distortion. So I'm finding the 6n23p is not
as good of a tube as the 6n1p(in an absolute transistor way), but if you need a more syrupy sound, as to listen to poorly mastered music, the 6n23p will do just that.
