@Music Alchemist,
As to what Vidars would do for your speakers: I don’t think this is predictable. In general, most quality amps work well with most good speakers, however…
Some of my amp experiences:
—some years ago I bought an inexpensive SS amp from Radio Shack to use for breaking in new single full range drivers. (Whether or not you believe new SFRDs, as opposed to drivers in commercially built speakers, require break in, all I can tell you is that IME, SFRDs can take several hundred hours of run in before they settle down; note that T/S parameters change during this time, so there are physical measurements to show that something is going on.) That amp was totally unlistenable on the drivers I tried; sibilant and screechy like nothing else I have ever heard. Put that same amp on most any two way speaker and it sounded reasonable good (but not great). Why? IDK
—I built a pair of Metronome speakers using Fostex F120A drivers to see what all the fuss was about with alnico drivers. Using my Yamaha CR-1000 and Sansui 4000 SS receivers, the F120A sounded terribly rolled off in the highs and seriously mediocre otherwise. Martin King (of
http://www.quarter-wave.com/ ) brought over a PP tube amp to try; that tube amp had performed poorly on all the speakers he paired it with; it produced no bass! Paired with the F120A drivers, you wouldn’t know it was the same driver you heard on the SS amps, nor the amp you heard on the other speakers. Sweet, sweet music! From top to bottom, the sound was exceptionally good. The F120A sounds great on all the tube amps I have paired it with. Why? IDK
—As previously mentioned, I have tried my ST-35 tube amp on the FF225wk driver speakers I built. The bass is loose & flabby. Why does the ST-35 work great with the F120A and less than wonderfully with the FF225wk? IDK
If anyone has a method for predicting how an amp will pair with a speaker, I really want to know about it!
Cheers, Jim
