Schiit Owners Unite
Discussion in 'Headphone Amps (full-size)' started by hodgjy, Mar 15, 2012.
153 154 155 156 157 158 159 160 161 162
164 165 166 167 168 169 170 171 172 173
  1. ilikepooters
    This.
    The audio signal still has to flow through all the cheap components and cheap solder in its path.
  2. azteca x
    I'd say that's a little hyperbolic.  Cables won't imbue your music or audio with magical properties, but something like the Blue Jeans RCA compared to an umarked $2 cable from an anonymous Chinese factory - I'd say there's a bit of difference, and measurements of their electrical properties certainly reflect that.  Do I see a whole lot of reason to spend MORE than you would on the Blue Jeans?  No.  But if you have solid components and want to rest easy knowing your signal is unmolested by poor design, pick some up.  Or don't.  Just dig the tunes!
  3. MattTCG
    Get the bluejeans cable. Good quality and reasonable price.
  4. markm1
    Much Thanks.
  5. azteca x
    Not to mention they are made to order in America from Belden (also American) cable, if you're from the USA and into that.
  6. HPiper
    I second the Bluejeans Cable recommendation, very good cables and very good prices as well.
  7. markm1
    Thanks for the cable recommendations. Sounds like Bluejeans is the way to go.
  8. bearFNF Contributor
    [​IMG] um, they indeed do something, because, if you don't have them, there would be no sound at all...[​IMG]
    But on a serious note, getting a good quality cable is important, this does not mean more expensive, just good quality.
    Argo Duck likes this.
  9. pelli
    Neither will trolling...
  10. mac336
    will the hybrid Ragnarok have the same power output into the speaker outputs (100 watts into 4 ohms) that the solid state ragnraok does ?
  11. Erukian
    When is it trolling? He was responding to a specific question about whether it's worth it to pay extra for cables.
    This is just my two cents, but it seems like anytime someone expresses their opinion about cables on here where they're a non-believer they're automatically trolling. If they're a cable believer they're seen as sharing their experiences because cables are SO subjective nobody will tell them they're full of BS. Aren't double standards fun?
  12. Erukian
    Pretty sure Jason just added $50 to the MSRP of the hybrid statement amp by you asking that question! [​IMG]
  13. hodgjy
    He should just go ahead and rename the statement amp as Voldemort.
  14. BLACKENEDPLAGUE
    Then he would owe licensing fees
  15. hodgjy
    It was a joke about "the name we shall not mention."
