gmahler2u
- Dec 19, 2011
Congrats! Would love to hear you take vs the '74 SWGP Silver Reflektors.
I need some time to get use with this baby first. Yes, I'll try to give you some of my opinion.
Nice collection! Did you ever get a tester?
Out of the 11 '75 single wire posts none were with silver shields and closed plates?
That is interesting on the one with the closed plates - the rest open like the '75 plate posts. I didn't include they 75 SWGP Grays in my review recently. That peaked my curiosity. So I just did a mini face-off between the two. I'll post seperately.Haven't managed to get a tester yet. But it is on my To Do list.
And no, not even one silver shield.... However, one of the grays does have closed plates, which I thought was interesting....
That's a heart breaker! Yes, the vacuum was lost and air seeped causing the getter flashing to evaporate. She's done. This does happen occasionally to tubes. I've never had a Voskhod or Reflektor fail this way, but had a Siemens early '60s CCa die and a Philips Miniwatt...I feel your pain.Bad things are happening. First of all I warn off a Grado owner from the Lyr because mine has a hum which becomes epic with the low impedance Grados - and folks chime in to say 'Hum? What hum? Our Lyrs are silent." Someone suggested that it might be the tubes - so I tube-roll (the hum is still there) and when I pick one of my preferred go-to tubes I find this:
Which should look like this:
And has been carefully kept in this:
What's going on? Some enemy hath done this.
And my Lyr hums.
Those 7963 are very cool! Rick swears by them.Since my amp (not a Lyr) uses only one double triode as a driver, this makes me think I should try to compare the gray '75 SWP with closed plates to the open-plate version. Plus I am still working on a adapter for the Sylvania sub-minature 7963. And I recently picked up a pinched-waist E80CC and a pair of C3g/s - all ultra-linear with frame grids... An "embarrassment of riches".... .
Tube went bad....air leak.
Have you called Sch**t up about the hum? Tried other hps? Tube risers, I had one fail on me (check the little gold pins in the receiver socket)? I'd give a different pr of rca connectors a try.
One channel or both?
Have tried another hp, even just some ear buds? I have old pair AKG 701s, 62 ohms, I get no hum from my lyr.I shall look up the funeral services for tubes. The hum - I've tried different interconnect and no interconnect and the hum is still there. I've also tried a different mains cable. Thank you for your question regarding the channels - I hadn't thought to check. It's more prominent in the right channel. Faint in the left channel.
