Schiit Lyr Tube Rollers
Dec 28, 2017 at 7:16 AM Post #15,618 of 23,493
Dec 28, 2017 at 10:24 AM Post #15,620 of 23,493
Anyone have any single tubes they may want to part with? Just snagged an
Ember V2 and don’t want to split up my current sets. It uses a lot of the same tubes the L2 uses. PM me if you have something descent you don’t need anymore.
Dec 28, 2017 at 3:20 PM Post #15,622 of 23,493
Give those 2 star Amperex E88CC a whirl, they will either be your favorite or 2nd favorite Holland tube, pitted right up against the PW pair I sold you. They are that good IMO.
Dec 28, 2017 at 3:57 PM Post #15,623 of 23,493
I have an extra WE396A that I can shoot your way @koover
Dec 28, 2017 at 4:44 PM Post #15,625 of 23,493
I have a single Amperex D getter standard pins. I will have to get more details when I get home.
Cool. Let me know when you get a chance
These I got to think about. You’re taking about the post in the classifieds correct? Pricy at this moment. New amp, new Headphone.
I emailed Jeremy from Garage and he said this is one variant they’ve never tried in this amp. Don’t know if it’ll be compatible. If it needs an adapter, not sure which One I’d need.
Damn, @koover about to end up with the best singles collection of all of us by the end of this week :beyersmile:
Haha. Could be. I’ll also PM you when I get a chance.
Dec 28, 2017 at 5:02 PM Post #15,627 of 23,493
The WE396A is basically a 5670/2C51, so if it takes those, you'll be fine. Like the Schiit amps, you'd need the 5670 to 6922 adapters with them, but I'm assuming you already have some.
Dec 28, 2017 at 5:22 PM Post #15,628 of 23,493
Yes, I have that adapter, but is it compatible with the Ember? I would think so if it already takes the 6922.
I was just surprised Jeremy from Garage 1217 couldn't give me an answer as they've never tried running with that tube in this amp.
I would assume my 6N3P, 6N3P-E and 6N3P-I would also work in this amp?
Here was his response
That is one of the few combos we have not tried so it falls into one of those - it should work with the proper adapter categories. With the 2c51 have micro small plates, I imagine it would be suceptible to noise, a lot more so than later dual triode designs with larger plates. Could be a fun adventure :)
So maybe he did answer as I'm going to go for it.
Dec 28, 2017 at 5:31 PM Post #15,629 of 23,493
Koover, try it and see. Shouldn't hurt anything to try them.
My Budgie phono amp takes 6922's but no go with the 5670+adapters....they just made a buzzing and pulsating noise.
Dec 28, 2017 at 5:35 PM Post #15,630 of 23,493
Looking at the spec, I'd think it would be fine with adapters, but given the list you can use, I'm not sure you need to worry about it :)
From the manual:
- 300mA to 1000mA heater current draw tubes can be used
- 6V and 12V miniature 9 pin heater voltage tubes can be used
6V TUBES: 6922 7308 8223 6AQ8 6DJ8 6GU7 6CG7 6BQ7A 6H23 6H23N 6L12 6N11 6N23 6N1P 6N2P 6N6P 6N30P B719 Cca CV2492 CV2493 CV5358 E88CC E89CC, E188CC E189CC E288CC ECC85 ECC88 ECC89 ECC188 ECC189 ECC288 ECC289 JAN 7308 6GM8 6N27P ECC86
12V TUBES: 5751 5814 5814A 5963 6189 6201 6681 7025 7058 7729 6L13 12AD7 12AT7 12AU7 12AX7 12BH7(A) 12DF7 12DM7 12DT7 A2900 B152 B309 B329 B339 B749 CV0455 CV0491 CV0492 CV4024 E81CC E82CC E83CC E181CC E183CC E283CC E811CC E812CC E813CC E2157 E2163 E2164 ECC81 ECC82 ECC83 ECC181 ECC182 ECC182 ECC801 ECC803 ECC803S
