Yeah, mine is like that. I actually like it as I usually don't touch the volume but if I do, I can "find" it.
Schiit Jotunheim Review / Preview - Head-Fi TV
- Thread starter jude
kellte2
- Dec 21, 2004
O
Good point! Didn’t think about that, but might be better than the alternative: an overly sensitive pot. As long as it’s normal behavior, I am happy with it.
Thanks!
Thanks!
FLTWS
I notice it on my Jot and MJ2, I don't think it means anything. Old habits die hard and I'm use to giving a volume control a couple of full range swipes before starting an preamp/amp especially if it's been sitting idle for a number of days. May not really be necessary with the newer pot designs. I'm thinking back to the 60's and 70's.
Mine is like that, too.Nit picky question: does anyone experience any resistance when first turning the volume knob after a period of no use? It may be that the amp is relatively new and cold, but the knob almost has a slight stick when first adjusting the volume after a period of time without use. Afterward, the pot is smooth as can be.
Yup. I tried a Liquid Gold once and the volume pot was so easy to turn you could bump it and possibly damage your ears by accident.O
Thanks!
Yes, I do, doesn't bother me.Nit picky question: does anyone experience any resistance when first turning the volume knob after a period of no use?
Tuneslover
Project Ember has a really smooth volume knob too.
aisalen
- Mar 17, 2017
Ordered one with the internal dac, will compare with my smsl m8 hear the difference. Pairing with the incoming hd650 to taste desktop setup. I am using speaker system at home and go mobile with wm1a and iems at work.
To my ears listening through er4-xr using jot fed by dragonfly red is far better than the internal dac, the clarity and separation is certainly a step up. Am I Illusioned?
JohannLiebert
- Jan 18, 2012
Can I connect my Jotunheim to my playstation 4 and my ps4 to my acive speakers? Anyone tried this?
GrussGott
- Sep 18, 2016
I have no idea how a playstation works, but if it has audio outputs that can be converted to RCA in on the Jot then why not?Can I connect my Jotunheim to my playstation 4 and my ps4 to my acive speakers? Anyone tried this?
dr cornelius
- Apr 3, 2014
What outputs does PS4 have? The Jot has one set of RCA and Balanced ins/outs. Also, it doesn’t have optical or coax dig inputs, just optional USB... The RCA or Balanced outs will go to your powered speakers...
JohannLiebert
- Jan 18, 2012
It has one digital out only.
rkw
Then you would also need a DAC between the PS4 and Jotunheim.It has one digital out only.
JohannLiebert
- Jan 18, 2012
I have the focusrite 2i2. It is not a dac though. Wouldnt' do right?
I was eyeing with the iDSD micro as well.
Total: 6 (members: 0, guests: 6)
