Schiit Gungnir DAC
Discussion in 'Dedicated Source Components' started by warriorant, Mar 29, 2012.
329 330 331 332 333 334 335 336 337 338
340 341 342 343 344 345 346 347 348 349
  1. RCBinTN
    Please come back and tell us what you think about your GMB...
    Happy Listening!
    RCB
  2. Loquah
    I agree. I did a lot of comparisons a while ago and found that the Coax was vastly superior to pre-Gen 5 USB, but the difference is much closer now. Coax is still marginally better, but it's close enough that I've dropped back to using USB for the sake of convenience for computer audio.
    RCBinTN likes this.
  3. jrflanne
    I have a bunch of iTunes downloads in my library. The Gumby works great with those. I suspect the combo burrito filter has a lot to do with that. So, buy the Gungnir, listen to your AAC’s, and get rippin.
    RCBinTN and tcellguy like this.
  4. gordec
    I'm interested in getting an used Gumby on classifieds. Is there a significant difference between the different USB generations?
  5. luckybaer
    Gen5 is what you want to get if you want well-implemented USB.
    Per Schiit:
    Gen 5 USB: USB, Solved
    Forget decrapifiers, regenerators, isolators, and all the USB dongles and boxes you’ve been told you need for USB sound. Our all-new Gen 5 USB input doesn’t require any of that stuff. It’s this simple: Gen 5 is USB, solved. Now standard on all our upgradable DACs, Gen 5 USB features full galvanic isolation via transformers, self-power for low noise and latching, and high-quality local clocking for both 44.1 and 48k multiples.
    RCBinTN likes this.
  6. Second Gear
    I had an opportunity to compare Gen 2 vs. Gen 5 Gumby's via a Ragnarok + HD600 for about a day. It was casual. Everything at polite volume with some of my newer favorite blues and jazz tracks.
    IME, I did not hear a significant difference or maybe any difference. The source was a 2014 rMBP 15 running Roon and connected to the DAC with a Schiit cable.
    gordec likes this.
  7. gordec
    Thanks. Good to know. I guess don't need to be too picky as long as price is right.
  8. Globox
    I think that it... Depends...
    Lets say that you have a great USB output on your computer. It wont change anything.
    Let's say that you have a crappy USB output on your computer. It will make a great change. You won't have any noise anymore.
  9. wgallupe
    Getting a good price on a used unit is hard to do. They all seem to sell for 85-90% of a new unit. That differential is not enough for me personally. Especially when you don't get a warranty with the used unit.
    rutter likes this.
  10. Audiofiend1
    Well i have a bit of a horror story here goes...(it does have a happy ending though).
    A few days ago i was travelling intentionally out of San Francisco, i was going abroad for quite a few months and so, i decided i wanted to take my Gumby multi + MJ2 with me. I packed them both into a pelican case with foam perfectly cut out to match their dimensions. There is absolutely no play in the case for them to move around, the fit is perfect and i felt that the case was doing a good job of protecting these items. I showed up at the airport and the airline informed me in no uncertain terms that their policy had changed and i was not allowed to take an extra carry on item as i had done many times before.
    With my plane taking off in 2 hours i was faced with a choice, either miss my flight or check in my pelican case containing my Gumby multi + MJ2 as check in luggage. All i could think about were the horror stories of cases being thrown around and roughly handled, furthermore i was scared that someone might steal my pelican case. I argued with the airline check-in lady that how was i to know that their policy had changed as i make this flight several times a year sometimes. They agreed to check my bag through as priority business with the highest clearance for no extra charge and so i agreed.
    Ten minutes later i was still not happy and ran back to the desk and asked the lady if there was anything else we could do, as i stressed the contents of the case were extremely fragile and i was petrified to say the least. She said she would see what else she could do and on my way i went.
    When i arrived at my final destination i went to the luggage carousel (ran is more like it) and was among the first to see the first set of cases coming out. What i saw shocked me as cases were being thrown more then 6 feet and landing on the carousal quite hard After roughly an hour of waiting to see my pelican case rudely thrown onto the carousal and watching people pickup their bags i was beginning to think my pelican case had been stolen. 15 minutes later the last person picked up their bag and the carousal closed, great i thought close to $3k in equipment stolen.
    Just as i was about to walk away a lady approached me and asked me if a pelican case was mine. She walked me over to another area and there was my case. She explained it had been carefully checked through as it was classified as fragile and so was not placed with the other check in luggage. There was also a big fragile sticker on the case so i was extremely happy that the check in lady back in San Francisco had actually listened to me and helped me out even though she was under no obligation to do so.
    My case had zero scratches on it and both my Gumby multi and MJ2 have never been in better condition. Still i learnt a lesson how dangerous transporting high end pieces of home equipment across the world can be and i won't be doing this again. So now i am looking to see if i can buy an amp/dac combo that is transportable but it needs to be comparable to my Gumby mulit + MJ2 combo, any suggestions would be appreciated.
    kehorton and earChasm like this.
  11. Globox
    Hi Audiofiend1, it wont be nearly as good, but it will be a lot easier to carry and definitly worth every penny : Fostex HP A4(or HP A4BL if you run balanced headphone).
    BTW, which pelican case did you buy ? I might be interested !
    Thanks !
  12. Ojisan
    Wow lucky you! I was curious if you were actually going to travel with the pelican case. Glad everything was safe.
    I used to do 100k+ miles of flight a year, all over the world, and I had times when I needed to carry small to very large pelican case with much more expensive equipment. The airport/airline has basically stopped using "fragile" luggage classification and it has become something that is honored only by employees who care. No guarantee that it will not be mishandled. I don't take that risk anymore and neither does our company.
    As much as I would love to have all my gear when I'm on the road, I now travel with Focal headphone only (hand carry) which sound decent out of my laptop. If I want to stretch it (and 115V can be managed), I would consider bringing my Jot (or Lyr3 if you prefer tubes) with DAC module. I'd be curious too if anyone knows smaller package that approach Gumby+MJ2 combo.
    Safe travels!
  13. Audiofiend1
    Yup i was crazy enough to go through with it! :grin: I think you are 100% spot on because i do not think that the airline i flew offers any kind of fragile service handling for cases, so i think it was completely at the discretion of the air hostess that felt pity for me. I really shudder to think what could of happened if it had been checked through normally.
    I was considering the Jot with the multi upgrade but i do not know how good it is/comparable to the Gumby multi + MJ2 ?
    @Globox Hey! I just looked up the Fostex HP A4BL it looks like an interesting combo. Any idea how it stacks up to say a Jot?
    As far as the pelican case goes, i settled on a 1535 Air edition. When i say that it is a perfect fit, it is literally a PERFECT fit as if it were built for this combo. There is not a single millimeter of space extra for the MJ2 + Gumby, It only moves a teenie bit within the foam. I could move the case violently up and down and the Gumby +MJ2 would not move it feels very secure and it was easy to cut the foam to match the exact dimensions,
    i even removed foam bits at the back for the plug end that stick out to make sure that it fit even better so my foam cutout is a bit of an odd shape but it works 100%. If i even need to move it again somewhere i don't think there is a better case out there, however airline check in is something i won't do twice no matter what case it is in.
  14. Globox
    I don't know the HP A4BL, But I have an HP A4, which is not as good as the BL.
    I don't know the jot ether. But, let say that my combo Gumby + MJ2 is not a lot better than my HP A4 with an LCD-X.
    Audiofiend1 likes this.
  15. Ken G
    You should sporadically check out the Schiit B-Stock/Closeout listing that they've been updating on a regular basis with new gear. Currently no Gungnir listed but I was able to grab a non-multbit (usb-gen 2, I think) for $600 about a month ago. They seem to add new stock weekly.
    And the 5 year warranty applies.
    http://www.schiit.com/b-stocks
    bildar likes this.
