Do yourself a favor and grab a Schiit Eitr. USB>Coax SPDIF. It beats most converters regardless of price.I haven't gotten my Gumby yet because it's backordered but I read a review that ranked the inputs as follows in terms of SQ and I was wondering if anyone else here has had similar results.
BNC> RCA SPDIF>optical SPDIF>USB
http://passionforsound.lachlanfennen.com/schiit-gungnir-multibit-dac-meet-gumby/
I don't have a BNC output on my computer but this review leads me believe it would be a good upgrade. Thoughts?
Schiit Gungnir DAC
- Thread starter WarriorAnt
Boogie7910
- Mar 20, 2008
I have an optical out already so won't be using usb. Mainly I wanted to know if people had the same experience as the reviewer with the bnc connection being superior .
I tried everything except BNC ... don't have it at source. IME S/PDIF coax beats USB hand down ... it's not a 'slight' difference, either. GMB's USB Gen 5, I understand, is a big improvement over Gen 2. Optical wasn't the same difference ... I'd say it was a small improvement. I'm currently using a Singxer F-1 (equivalent) USB-S/PDIF coax converter and this gives very good results in my setup (see sig). I have ordered the EITR, rather than upgrade the GMB at this stage ... it may even beat the F-1 but if not, it will also serve duty with another setup I have in the office. Shame the EITR doesn't output BNC but I guess that could be a more limited market and would increase cost/price and perhaps might not fit the small-factor case.
Don't worry about BNC with Eitr. Coax is fine. You can get a coax to BNC converter but at that point it's just more stuff in the signal path. Eitr is the Schiit, literally. My only complaint with it is it has a slight audio delay. Very slight, most won't notice it but with competitive gaming and music creation I do.
BNC is Coax. "The BNC (Bayonet Neill–Concelman) connector is a miniature quick connect/disconnect radio frequency connector used for coaxial cable." The signal uses the same S/PDIF protocol and goes to the same S/PDIF receiver based on the AKM 4113 chip. If you use a good 75 ohm impedance coaxial cable with the Coax input the results will be indistinguishable from using the BNC input.
Because the Coax input uses a universal RCA socket some people use crappy not even coaxial cables and post here how crappy the sound is. Because it is practically impossible to find a crappy BNC cable all the posts about the BNC input are positive. Hence the presumption that the BNC input is superior to the Coax while they are the same.
deserat
- Oct 9, 2015
If the Gumby hasn't shipped yet, it will come with Gen 5 USB, no need for Eitr.
Agreed ... this is to me the one area where the quality and spec of cable IS truly important, the RCA S/PDIF Coax.
Some common sense is always welcome around here! Big thanks for sharing this.
RCBinTN
I think what you wrote about the quality of digital connections is consistent with what Mike @Baldr had posted earlier.
On top at #1 would be the AES/EBU, but only Yggy supports that, not Gungnir.
Personally, I am using an optical connection, and happy with it.
With the launch of the Gen 5 and Eitr, however, USB may leap ahead of optical into 3rd place.
I think if you are able to use BNC/RCA, which are almost the same, then use them.
Since my source is a Mac computer, I don't have the BNC/RCA option unless I use an intermediate converter. Therefore, the toslink.
Baldr
Sponsor: Schiit Audio
- May 14, 2011
It goes something like this today: BNC about equals Coax about equals Gen 5 USB>TOS>>Gen 3 USB. "About equals" means close to very close with tradeoffs.
Stay updated on Schiit Audio at their sponsor profile on Head-Fi.
artur9
- Apr 25, 2015
I wish all stereos had BNC connectors instead of the annoying RCA. No loose connections that way.
@Baldr, tradeoffs?
@Baldr, tradeoffs?
PolarBehr
- Dec 24, 2016
@Baldr, tradeoffs?
I worked in the broadcast industry for a while back when a lot of BNC connectors where used for analog video. They are much more reliable and robust than RCA connectors but to state no loose connections is not correct. I saw a lot of BNC connectors with sloppy tolerances and a lot that had faulty and intermittent cable to connector assembly. BNC connectors do not solve all cable issues. A lot of time was spent chasing faulty cable connections.
If you are looking for RCA or coax SPDIF cables, Blue Jeans Cable connectors have a good grip for a solid connection.
Since the Gen 5 USB has come out and will come with your Gumby, that evaluation is obsolete. Initial Gen 5 USB reviews from users are quite good -- on par with SPDIF. Regarding AES vs SPDIF vs BNC, here are Jason's comments regarding the differences.
If anyone needs more details on the differences among AES, BNC, S/PDIF they are super easy to find: https://en.wikipedia.org/wiki/S/PDIF#Hardware_specifications
AES has the highest signal output level (7V), then BNC (1.2V), then Coax (0.6V); max cable lengths - 100m, 1000m, 10m respectively. AES and BNC were designed for professional applications where one would need to run hundreds of meters of cable (concerts, large studios etc.), S/PDIF - for consumer applications. If your AES, BNC, coaxial cable is under 10m of length there should be virtually no difference.
