Try re-seating all of the tubes. If that doesn't help, you may have a grounding issue at your outlet.First impressions are very good. With HD800S I noticed very nice and big soundstage with an excelent separation and layering. But I also hear a lot of hum - the more tubes are heated, more hum i listen. Anybody else have such an experience?
Schiit Folkvangr - Impressions Thread
- Thread starter XERO1
Beefy
- Mar 4, 2008
As pretty as your Schiit stack looks, I suspect you have magnetically induced hum from the proximity of the two pieces of gear. Give them some space, I'd wager it goes away.
Nope… I’ve run the stock tubes for the first several weeks and have since rolled all the tubes ( + several sets of 6n1p alternatives) and haven’t had any noise/hum issues. Just crackle when it’s turned off. I am primarily listening with 800s as well.First impressions are very good. With HD800S I noticed very nice and big soundstage with an excelent separation and layering. But I also hear a lot of hum - the more tubes are heated, more hum i listen. Anybody else have such an experience?
I think @Beefy is right…the stack may be the issue. Jason does mention that as a thing to be aware of.
Orange5o
PastorOfMuppets
The crackle is so awesome.Nope… I’ve run the stock tubes for the first several weeks and have since rolled all the tubes ( + several sets of 6n1p alternatives) and haven’t had any noise/hum issues. Just crackle when it’s turned off. I am primarily listening with 800s as well.
carbonF1
Hi all, any thoughts comparing Folkvangr to WA22? I've only read one comparison, but factoring in tube upgrades Folk seems about as good and much cheaper over the long run even with the 8 6n6p tubes.
I'm stacked identically and no hum. Well, maybe a tiny little bit on high gain with Grado's, but not lo gain and not at all with 6xx. Full vol no signal I get nothing.As pretty as your Schiit stack looks, I suspect you have magnetically induced hum from the proximity of the two pieces of gear. Give them some space, I'd wager it goes away.
bokononista
When i raise the Folkvanger, hum intensity is still the same. Its also independed at volume level. Just the tube heat matters. No hum with Valhalla. Ill try reseating or change tubes but it may be grounding issue.As pretty as your Schiit stack looks, I suspect you have magnetically induced hum from the proximity of the two pieces of gear. Give them some space, I'd wager it goes away.
No. Hum free unless I go past about 3:00 on the volume dial in high gain. Nada in low gain. One of the things that impressed me about the FV is how quiet it is compared to the Woo WA6-SE. It also seems well shielded from a nearby wifi station (which I can hear on the Woo).First impressions are very good. With HD800S I noticed very nice and big soundstage with an excelent separation and layering. But I also hear a lot of hum - the more tubes are heated, more hum i listen. Anybody else have such an experience?
Had a similar problem once and used the below. Solved the problem, though I have no idea how it works. That said, the fact that noise increases as the tubes warm up suggests it may be a bad gain tube (6N1P), though most likely you would only hear it on one side.When i raise the Folkvanger, hum intensity is still the same. Its also independed at volume level. Just the tube heat matters. No hum with Valhalla. Ill try reseating or change tubes but it may be grounding issue.
https://audio46.com/products/ifi-silent-power-gnd-defender?currency=USD&variant=39595497291966&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&_vsrefdom=adwords&gclid=EAIaIQobChMIxfaVq4aI-gIVCxpMCh1gAQ4_EAQYASABEgJeePD_BwE
bokononista
Maybe i will try, thank you. When other sets of 6N6P arrive, I also try to change them. Changing 6N1P do not help.Had a similar problem once and used the below. Solved the problem, though I have no idea how it works. That said, the fact that noise increases as the tubes warm up suggests it may be a bad gain tube (6N1P), though most likely you would only hear it on one side.
tg123
- Mar 11, 2014
The Koss KPH30i with the Grado like ear pads mod, works well with the impedance multiplier too.I use the Folkvangr with impedance multiplier on with my Grado GS3000e. Sounds very good. As does the LCD4. I believe Jason has mentioned he uses Grado headphones with it as well. It is more flexible than many believe. I thought it sounded pretty good with my Focal as well.
Have different amount of hum left/right?Maybe i will try, thank you. When other sets of 6N6P arrive, I also try to change them. Changing 6N1P do not help.
Try to swap all 6N6P tubes from the left side to the right side and vice versa. If the hum also switches sides, swap tubes left to right again but pair by pair. When the hum moves again you’ve found the offending tube. Maybe not worth the hassle, but it should work..
bcowen
I've had no hum issues at all with mine, but when I got it the volume pot had a loud scratching sound in both channels when rotated (with no signal). I ran it back and forth quite a bit thinking maybe there was some debris or film on the pot's wipers that would go away, but it didn't help. Was vacillating on sending it back to Schiit for a look, but in the meantime I pulled the 6N1P's out to try some 6N23P's. No more scratch. In the tester, one of the 6N1P's was fine, but the other had extremely high interelement leakage...enough to be getting close to a short. Not sure why the scratching sound was of equal volume in both channels, and can't say I've ever had a bad/marginal tube manifest itself in this particular manner before. But I've done several input tube swaps since then and no further issues, so I'm blaming the tube even if I don't fully understand the why's of it. I suppose I could ask Schiit to send me a new 6N1P (or pair), but as I wouldn't use them anyway I thought it a bit petty to waste their time with it. Currently rocking some D-getter Holland Amperex 6DJ8's that sound quite wonderful. And I haven't even started adapter-ing. Yet.Maybe i will try, thank you. When other sets of 6N6P arrive, I also try to change them. Changing 6N1P do not help.
same issue with my FV. I've been told that the tubes needs to burn in. I don't know.First impressions are very good. With HD800S I noticed very nice and big soundstage with an excelent separation and layering. But I also hear a lot of hum - the more tubes are heated, more hum i listen. Anybody else have such an experience?
Total: 5 (members: 1, guests: 4)
