Schiit Bifrost Uber Analog Upgrade
post-10693025
Post #1,066 of 1,446
StanD
  Hi,
Just wondering if anybody could help, I have had the uber upgrade fitted for a while now and I have just fitted the USB Gen 2 upgrade today. When I go into playback devices / Shiit USB Audio Device / Advanced its does not show 24/176.4 but shows 16/176.4 ?. I am using Windows 8.1 if this helps at all.
Thanks in advance, Paul.
Did you install Schiit's driver, from their website?
post-10693142
Post #1,067 of 1,446
Syan25
After rethinking the whole thing - I'm going with the Gungnir...
post-10693297
Post #1,068 of 1,446
StanD
And the reason is? Are you looking to get into a balanced amp, etc?
post-10693476
Post #1,069 of 1,446
Byrnie
FYI the Gungnir also has RCA outs on it.
post-10693523
Post #1,070 of 1,446
StanD
Yes, but a Bifrost has that as well. The question is why the Gungnir? Which is why I brought up the balanced I/O.
post-10693555
Post #1,071 of 1,446
Syan25
I do want balanced output but I also want two RCA outputs for convenience sake...
post-10693700
Post #1,072 of 1,446
kothganesh
+1. I find the Gungnir (for a few dollars more) is more versatile. I can switch between the Mojo and the KGSShv (balanced outs) or the Crack, Emotiva, ZD (RCA outs) fairly quickly.
post-10693941
Post #1,073 of 1,446
Rapid7
UK
UK
Age
47
Yes I have installed the drivers, I contacted support and they said that it wont appear till I have ASIO installed ?
Thanks.
post-10694263
Post #1,074 of 1,446
StanD
post-10694387
Post #1,075 of 1,446
Rapid7
UK
UK
Age
47
  This one is popular. I use it with my DAW software.
http://www.asio4all.com/
Thanks, but surely it would show up in windows audio properties? 24/176.4 and not 16/176.4 I wouldn't have thought that installing ASIO would make this show up in audio properties.
post-10694826
Post #1,076 of 1,446
Syan25
On a different note, has anyone tried an ipod using the onkyo nd-s1 digital transport into any Schiit DAC? I wrote to them about this but their technician had no idea. They suggested the pure i20, which is possible to buy here in Taiwan.
post-10697432
Post #1,077 of 1,446
StanD
It looks like it has both optical and coax SPDIF out, so in theory it should work with either the Optical SPIDF Modi, Bifrost or Gungnir.
post-10697487
Post #1,078 of 1,446
kothganesh
Hi Stan:
What has your experience been with the SPDIF ? I used to have a bridge that I don't use since its apparently limited to 24/96 (I know, I'm trying not rake up the why you need more than 44.1 issue).
post-10697497
Post #1,079 of 1,446
StanD
  Hi Stan:
I have a USB to SPDIF converter optical/coax as well as a FiiO E18 which can do the same only coax but limited to 24/96. Both worked fine connecting to my Bifrost, however, I didn't try it with anything above 24/96. My converter can go all the way to 192 but as I said, never tried it above 24/96. I bought the converter just to see how it would work.
post-10697502
Post #1,080 of 1,446
kothganesh
I have the BNC Halide bridge. It sounded fine on the Bifrost and Gungnir but when I went USB to USB it was my sense that the overall sound became fuller and a tad more refined. I think the USBs on the Schiit DACs are implemented very well. Thanks.
