Schiit Bifrost Uber Analog Upgrade
49 50 51 52 53 54 55 56 57 58
60 61 62 63 64 65 66 67 68 69
  1. kstuart
    Send that question to schiit's email address.
  2. kstuart
    The Schiit Gungnir (sp?) is the same thing as the Uber plus balanced capability.  If you like the KGSShv then you should sell your Uber and buy a Gungnir.
  3. kothganesh
    I already have the Gungnir [​IMG]. This is my office set-up where I have the Bifrost Uber.
  4. tuna47
    Is the gungnir worth the up grade over the bifrost uber
  5. madwolfa
    It is if you have a fully balanced setup - amplifier and headphones.. Even then, I doubt you would be able to tell the difference.
  6. Byrnie
    Monoprice.com should have cables for that just navigate to the pro audio section.
  7. ToTo Man
    I have just borrowed an Uber Bifrost which has given me the much appreciated opportunity to A/B it against my existing non-Uber Bifrost, and so I wanted to contribute my thoughts to this very helpful review thread.
    I usually have my non-Uber Bifrost connected to my Mac Mini by USB as this enables me to enjoy the whole gamut of source material from 16/44 through 24/192, but for the purposes of a fair A/B test my hookup is as follows:
    Mac Mini -> toslink cable -> toslink-to-spdif-converter -> spdif cable -> rca splitter --> Uber and non-Uber Bifrost spdif inputs.
    (I tried a toslink splitter but couldn't get either Bifrost to reliably lock onto the signal, hence the toslink-to-spdif converter).
    The amp I'm using allows seamless input toggling with zero silence or delay, which is ideal for A/B testing.
    First thing I notice on A/B comparison is that the Uber is subjectively "louder" than the non-Uber.  The difference in volume is very subtle and I have not attempted to measure it using my SPL meter, but I'd guess at most 1dB louder, possibly even less, but the difference in volume is noticeable to my ears when toggling back and forth.  This level difference is slightly problematic for A/B testing, because as you know, the louder something is the better/clearer it tends to sound, but there's no easy way to address this.
    Second thing I notice on A/B comparison is a difference in mid-frequency clarity and level.  The Uber unit is both more forward (i.e. louder) and more transparent (i.e. clearer) on mid-frequency content (most notably on instruments like vocals and piano), than the non-Uber unit which sounds more distant and slightly veiled/muddy in these frequencies by comparison.
    Also, and I find this the hardest to describe without risking sounding all "arty-farty" (which is very out-of-character for me!), but there is an ethereal quality to the mid-frequencies in the Uber unit, as if vocals and piano are projected with a 3D-like aura around them which is very pleasant and engaging to listen to.
    Low frequency and high frequency tonality is similar between the two units and I struggle to hear as much difference at these ends of the spectrum than in the mid frequencies, but I'd still give the edge to the Uber.  Bass seems better placed in the soundstage and more 3D-like, and high frequencies are more easily distinguishable.
    I will readily admit that, if I did not have real-time A/B testing facility available to me, I may struggle to detect any of the differences I noted above because I'd probably think my ears were playing tricks on me.  But the real-time A/B testing really does prove that there are indeed sonic differences between the two units!
    eddypoon likes this.
  8. bluesound
    How about connecting TV via toslink to optical Bifrost then pre-amp to amp?  Is anyone doing this? I'm attempting this with new Bifrost Uber unsuccessfully. Thanks for any ideas.
  9. Tuco1965
    The Bifrost doesn't handle Dolby Digital.  So that would be a no go.
  10. hodgjy
    Most tvs will convert Dolby to PCM on the fly, but then your receiver would have to use Dolby Pro Logic to simulate the 5.1 track.  That's not a good way to go.
  11. bluesound
    I'm not using a receiver but trying to run sound from the tv (optical) to Bifrost, next pre-amp then amp in that order for just 2-channel phantom tv audio. I'm also running a Squeezebox Duet through the co-ax input on the Bifrost, same order and works fine.
  12. kothganesh
    +1. The Gungnir is probably a perfect match for the Mojo (IMO). Having said that, the Bifrost Uber is startlingly close to the Gungnir. I use the Uber with the Ec Zana Deux and the KGSShv. With the Zana, the detail, clarity etc are amazing. However, to my ears, it falls a little flat with the KGGShv. I don't know if it has to do with going from SE on the Bifrost to balanced on the amp. Need to experiment with the Gungnir and the KGSShv ( I got this last week).
  13. Rusty143
    Anyone use the über Bifrost with the Valhalla and sennheiser cans? I'm considering buying the Bifrost and Valhalla to pair with Sennheiser HD 600 cans.
  14. ToTo Man
    This is my exact setup!  Very revealing with great clarity.
  15. Rusty143
    Fantastic!!! What source(s) are you using? What kind of music do you listen to? Do you find the sound smooth and engaging? I'm hoping with this combo the highs would be bright or sharp.
