Save BIG on our retuned AEON Flow Headphones; Only $499
Jun 5, 2020 at 10:04 AM Post #106 of 250
tim0chan
I'm curious to know if the RT models ship with any of the extra tuning filters preinstalled.
What do you mean? I got standard tuning filter installed
Jun 5, 2020 at 10:06 AM Post #107 of 250
roskodan
EU
Yeah I meant standard. Curious about which one of those come preinstalled on the RT open and closed.
Jun 5, 2020 at 10:17 AM Post #109 of 250
roskodan
EU
Made this combined Aeon, Aeon RT, Aeon 2, frequency response graph for myself, thought I'll post it here for others to scratch their brains too.
Jun 5, 2020 at 10:18 AM Post #110 of 250
roskodan
EU
Mine had the one notch white installed. It also comes with the black foam, black felt and white 2 notch in a bag with the certificate. I have the RT closed
Cool, I guess it's the same for the Open?
Jun 5, 2020 at 4:38 PM Post #112 of 250
corgifall
Colorado
I find the black felt on the closed to be a good compromise between "My ears are bleeding from the highs" to "The highs are too muffled". I find the single notch kills more of the sparkle of the top end than I'd personally like. With no filter you get a nice echo and more intense sound. Black felt seems to keep most of the sparkle and echo/wide sound with a little more thump from the low end. I really like the tuning kit! It's essentially a semi permanent EQ that works with all my sources.
Jun 5, 2020 at 5:06 PM Post #113 of 250
roskodan
EU
Yup, that's why I go with no filters on my o.g. AFO and o.g. AFC. But in my early head-fi days I abused the Beyerdynamic T1 quite a lot, so my brain doesn't mind a little bit of extra spark, as long as it's not that nasty Beyer stuff.
Jun 10, 2020 at 1:14 AM Post #114 of 250
corgifall
Colorado
I made a cable for the aeons. Well... converted an old null audio lune cable to the hirose connectors. Much easier than I thought it would be working with the hirose connector.
Jun 13, 2020 at 1:20 PM Post #115 of 250
MtnMan307
Arvada, Colorado
If we want to use this headphone with both balanced and SE amps, which cable do you recommend? XLR with a separate single ended adapter? I have a Jotunheim and a Lyr 3.
Jun 13, 2020 at 3:24 PM Post #116 of 250
CANiSLAYu
Bay Area, CA, USA
You have to go balanced to single-ended; can't go the other direction. So yes, if you don't want to swap cables you need one cable that ends in 4pin XLR male and then a 4pin XLR female to SE termination of your choice. Probably best to have 3.5mm that has a threaded 6.3mm adapter for the greatest compatibility. Something like this:
Jun 14, 2020 at 5:57 AM Post #117 of 250
russmarch
vermont
Can anyone speak to aftermarket cables and if they have any value as to improving the sound. Browsing the sale forums, someone had a cable that they stated was a night and day difference relative to improved sound, particularly soundstage, but when attempting to sell an item there is always the possibility of exaggeration to some extent.
Jun 14, 2020 at 6:23 AM Post #118 of 250
roskodan
EU
In such cases, regarding cables "there is always the possibility certainty of exaggeration to some the full extent.". There, fixed that for you.
Jun 14, 2020 at 11:11 AM Post #120 of 250
tim0chan
Lol. I was trying to be diplomatic about it. Especially when the cable that I went back after and priced would cost me more than the Aeons did.
Cables to me are bling with maybe a little sound quality increase, buy them for how they look (make sure they at least are decent internally) and not for how they sound, especially for a hp like the aeons which are meant to be very good value. Others may use cables as their last little tweak on their totl hps and to complete the look of their endgame system. To sum it up, aeon stock cable is nice, unless you want a different colour cable
