Samsung Galaxy S3 to DAC - USB Micro-B male to Mini-B male??
post-8925479
Post #33 of 65
Ripplinghurst
yes, cable has arrived and its the wrong one.  Not happybut its my own fault for relying on others.
post-8925930
Post #34 of 65
chinook9
Am I missing something here? How will this work? It's micro to micro, not micro to mini. Wut.
As just reported by Ripplinghurst, these won't work. I have bought a couple off eBay and they both work. The following one works but is a little stiff for my liking. http://www.ebay.com/itm/mini-USB-OTG-Host-cable-lead-Archos-Home-Tablet-7-/261127669335?_trksid=p2047675.m1985&_trkparms=aid%3D444000%26algo%3DSOI.CURRENT%26ao%3D1%26asc%3D13%26meid%3D3932288029254846192%26pid%3D100012%26prg%3D1014%26rk%3D2%26sd%3D251147285033%26 I believe the following should also work but I don't own it. http://www.ebay.com/itm/3Ft-1M-coiled-USB-Mini-B-5-Pin-male-to-Micro-5pin-male-Adapter-Spiral-cable-cord-/270878975614?pt=US_USB_Cables_Hubs_Adapters&hash=item3f11a5267e Search eBay using "USB Mini B 5 Pin male to Micro 5pin male" I just received a short 6" one from China that I paid $3.00 for (including shipping) and it works just fine. Good luck!
post-8929766
Post #35 of 65
CynicalMushroom
Yeah i found it weird that people were saying "thanks i'm buying these!" when they clearly won't work, oh well. Probably gonna buy the silver one: http://www.ebay.com/itm/USB-Micro-b-male-Mini-b-male-data-cable-lead-adaptor-/261135697830?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D3959359792674023981%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D251147285033%26
I think these are the same as yours, chinook9, but it says mine are about 4", not 6". Not that it matters.
EDIT: just read the description twice, it says "about 10 cm" under "Item Specifics" but then it says "about 15 cm (1/2 ft)" under "Specifications"
So i guess it's the exact same cable...
post-8930691
Post #36 of 65
CynicalMushroom
Btw, you mentioned that you found the cable stiff, is it too stiff to have in one's pocket together with an amp/dac+phone? Can you wrap it around the phone perhaps?
post-8931264
Post #37 of 65
NZtechfreak
That's the one I purchased, still awaiting delivery. Very slow, as it was last year when I brought my original USB OTG cable from them (incidentally the most famous OTG cable in the world!).
post-8931413
Post #38 of 65
CynicalMushroom
Do you find it stiff? I mean Is it soft enough to fit comfortably in a pocket?
post-8935220
Post #39 of 65
ozarkcdn
Have you guys compared the output from the S3 against the external DAC's?  I wish there was an easy way to ABX it, but it seems to drive my m50's pretty well!
post-8939722
Post #40 of 65
bitlisz
Hungary
Hungary
As I compared before, the sound with DAC+AMP (ODAC+Headstage Arrow 3G) was much more dynamic and better soundstage (more deep+wide), also much more silent the background (low noise).
After I switched back to SGS3 direct, I can confirm phone has enough power to drive my IEMs, but I always felt boring and dull, closed sounding.
And it seems the phone also makes sometimes small noises which an be easily heard when music is quiet.
post-8995466
Post #41 of 65
SilverSharpie
My apologize for being blind. I saw them a bit after posting and found another thread saying they work.
::edit:: just clarifying,  I shouldnt have posted in here about a micro to micro I'm sorry.
           The cable from hakshop is MICRO to MICRO.  If you are looking for a micro to mini there are many around the web.
post-9002564
Post #42 of 65
pandemic787
well for those who didn't read carefully enough, you can still connect your s3 to your friends s3 for "some peer to peer pwnage!"
post-9076513
Post #43 of 65
thebrockelley
Are you saying that with the Galaxy S3 and Note 2, a standard Micro usb to mini usb could be used to get audio through an amp? Or, would we still need an OTG variant?
post-9077003
Post #44 of 65
thebrockelley
Don't know if your answer has already been answered, but if you need a Micro-A to Mini-B USB OTG, I know of someone who can sell you some from China. It's going to take me a couple weeks to get them, but he only charges like $4.00, $5.00 with shipping and I live in Wisconsin. Here's the address:
http://www.ebay.com/itm/251211470827?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
