eggyhustles
- Jun 20, 2008
How would i go about getting Boeffla on a 4.2.2 rom(slim bean)
I have the sprint version(if it matters)
Can I use my own amp/DAC with the galaxy note 2? or will it only allow me to use the build in DAC???
Anyone saying there is no hiss is most likely deaf i have the note 2 and there is definitely hiss but its not as bad as a lot of stand alone players and its easily 99% better than every other android i've ever tried. No popping noises or EMI or CPU noises that i can hear. And if you want to see that hiss does in fact exist get into a really quiet environment and put your phones in and make sure nothings playing then change your ringtone or alarm sound and you'll hear the amplifier kick in with a super quiet hiss and the hiss will remain for a few seconds after the sound is not being played and its definitely there with music.
That being said you will definitely need to get a custom recovery like TWRP loaded onto the device and load up one of the half dozen kernals that enable boeffla sound. And as for the Amplifier boost setting 45 is stock and it goes to 63 which is nothing but distortion but with no EQ you should be able to boost it to 55 and stay pretty clean but i recommend never going higher than 45 as every single db higher just makes the hiss louder so if you have super sensitive phones you might even want to tone it down to 40 if there's sufficient volume for you as you can reduce the hiss to inaudible levels.
Uneak sound is really great but already freezed 2times in 20min.
Any suggestion for similiar sounding kernel?
