Samsung galaxy nexus
Apr 15, 2012 at 4:33 PM Post #121 of 249
EraserXIV
We rooting for all of you. Lol.
I see what you did there..
Apr 17, 2012 at 4:13 AM Post #125 of 249
DanBa
Just got my E17 today and flashed the kernel on top of AKOP m4,works perfectly!
Good news!
Probably a typo?
AOKP m4: Android Open Kang Project milestone 4?
http://forum.xda-developers.com/showthread.php?t=1402341
Could you please post some details about your configuration:
. ROM: AOKP m4?
. Kernel
. Audio resolution of your music files (16/44.1, 16/48 or 24/96)
. Audio resolution displayed on the FiiO E17 screen (16/44.1, 16/48 or 24/96)
Do you have another picture? (the current picture shows an analog out, and not a USB digital out)
Thanks!
Apr 18, 2012 at 12:42 PM Post #130 of 249
Deltaechoe
Unfortunately all he is doing there is amping the headphone out that has already passed through the phone's internal DAC, no modifications are necessary to do that.  The problem is getting a digital line out via the usb which bypasses the phone's internal DAC and uses the one in the E17 (or w/e usb DAC you use), so far we have gotten the kernel to recognize the DAC and load the necessary modules to use it, the only problem is we can't switch the phone's sound card from the default on board one yet and that problem is a bit of a toughie.  Without native ALSA support, it's going to be one heck of a hack
Apr 18, 2012 at 10:39 PM Post #131 of 249
revolink24
Have people gotten a true line-out from the galaxy nexus? I'm pretty desperate to eliminate the background noise.
Apr 20, 2012 at 3:07 PM Post #135 of 249
Gilly87
Member of the Trade: ApeSonic
Previously worked for Echobox Audio
Los Angeles, CA
Try setting PowerAmp eq totally flat and toggling it on and off; you will hear it. Same with the bass and treble knobs.
The best EQ for android is the DSP manager that should be available with most roms after rooting. It seems to be a straight hardware EQ and does not utilize any form of compression, at least that I can discern.
