shaunybaby
- Oct 1, 2010
Do you have balanced headphones? If so, which ones?
none.
If not, are you looking at balanced headphones or a balanced amp in the future?
at the moment i am looking into getting some lcd-2s and get those a balanced headphone cable, but im not sure where to start, but i already have your lyr amp and thats great so if you bring out balanced i will know what to buy next.
For balanced headphone output, how important is it to have dual three-pin XLRs as well as a 4-pin XLR?
i have been reading most of the posts in this thread and it seems like most people want 4-pin XLR, i don,t know what the differences are so i can,t say.
For a balanced amp, how important is it to also have single-ended outputs?
i think that if people are going to buy an balanced amp they should have the cables to go with it, you guys keep prices down and still bring out great gear i think adding a single-ended output is a bad idea if its ment to be a balanced amp.
If single-ended is important, is the quality of the single-ended outputs as important as the balanced outputs, or is this more of a “utility” thing so you can use all kinds of different headphones?
if you do go ahead and add one then it should be just as good as the 4-pin XLR out so you can compare.
none.
