wavoman
- Jan 19, 2008
This is twilight zone stuff -- I need help. Please!
The topic is S/PDIF. Connecting a Wadia iTransport to a Wadia DAC works perfectly. Connecting it to a Benchmark DAC-1 works perfectly. This is all with decent quality digital coax cables.
Now I want to run both DACs at the same time. I didn't want to open the Wadia DAC and change the internal jumper to enable pass-thru of the digital S/PDIF, so I bought instead a Sonifex Redbox RB-DDA6S S/PDIF digital distribution amplifier -- solid pro gear.
I connect the iTransport output to the input of the Redbox, and connect two of the outputs to the two DACS.
The BenchMark locks on to S/PDIF at 44.1 and performs perfectly. The Wadia DAC, however, locks on, but the music fades in and out ...maybe 1 second of outage for every 4 seconds of music -- not random, very predictable pattern.. And sometimes the Wadia DAC front-panel display flickers back and forth between "No Data" and "44.1"; sometimes the display stays fixed at 44.1 but the music fades in and out anyway.
And sometimes -- it works perfectly! Both DACs! Huh??
I have switched cables, switched ports on the Redbox, et. -- all to no avail.
Do you have any ideas why S/PDIF would fade in and out in that patterned way? Any clue that could point me in the right direction?
Note at all times the Benchmark works fine.
Thanks in advance for any insight, help, ideas, etc.
