jnorris
- Sep 12, 2011
I'm using the SMSL SU-8 with the RNHP and it sounds great. The SMSL has balanced outputs that can connect to the RNHP's balanced inputs, as well as regular RCA (unbalanced) that can be plugged into a preamp and on to an amplifier and speakers. Both balanced and unbalanced are active at the same time. The RNHP always wakes up to the balanced inputs so using them means you don't have to manually select the unbalanced to listen. Also, the turn on/turn off transient on the RNHP is pretty bad, so remember to disconnect your headphones before turning it on or off.Hello I would like to take one of this amp after reading some reviews, to use with beyer dt1990.
Could you suggest me a good dac to pair with it? (I will plug the dac do my pc).
And the psu supplied with this amp is good enough?
Thanks!
