RSA SR71b, quad mono balanced. img. 1 & 17 Review pg 32, 34, 68, UPDATED 4/2013 for Improved sound.
Dec 28, 2010 at 6:55 AM Post #498 of 1,194
techadd
would it be possible to do a portable rig setup of ipod -> protector (headphone balanced out) -> sr71 (headphone balanced in) -> balanced out JH13? :d
since i already own a protector, it seems fasicinating that using protector balance out to sr71b balance in would give me another experience in portable balance experience...
Dec 28, 2010 at 8:01 AM Post #500 of 1,194
jamato8
You could turn the 71B all the way up, so the volume control would essentially be out of the way and then use the Protector as a balanced preamp.
Dec 28, 2010 at 8:05 AM Post #501 of 1,194
Gorthon
But would gain would there be?  The SR71B already takes a single ended input and uses a phase splitter to create the balanced output just like the protector.
Dec 28, 2010 at 9:45 AM Post #502 of 1,194
Audio Addict
Just a note as I found originally when my SR-71B came in, it was set for a balance source.  I didn't notice it originally and actually listened for a day or so with the switch to balance.  For optimum sound, you may want to be sure the input source is set for S/E vs. balance.  While it does play, it is not the best sound.
Dec 28, 2010 at 1:39 PM Post #504 of 1,194
daveDerek
there'd be quite a bit of gain, especially if both amps are set to 'high gain', considering how much voltage each amp could swing!
Dec 28, 2010 at 2:00 PM Post #505 of 1,194
Gorthon
HA-HA funny funny.  Let me rephrase that then.  What benefit would there be,especially since he is uning JH13's?  The SR71B already takes a single ended input and uses a phase splitter to create the balanced output just like the protector.
Dec 28, 2010 at 2:32 PM Post #506 of 1,194
GeorgeGoodman
Considering the SR71B itself is well able to drive the HE-6, one of the most difficult cans to drive, to deafening levels, having the two amps in sequence would be more like the basis for a small audiophile boombox.
Dec 28, 2010 at 2:53 PM Post #507 of 1,194
nc8000
Kalundborg, Denmark
Using 2 amps can produce good results. I remember using a Xin SuperMini + SuperMacro that way
Dec 28, 2010 at 8:46 PM Post #509 of 1,194
jamato8
I first tried this with Xin's amps and then Xin thought he might make a preamp and an amp with no volume control. I converted a SM3 to an amp only, getting rid of the volume control. I liked the results but what is the point of have a preamp, amp, source and then the phones or IEM's. but for home it was fun. I think in general, the less in the signal path the better. It still might be interesting. Oh, I have adapters. I could use a Toucan and the 71B together totally balanced with balanced into which ever one is the preamp.
edit: tried it. The sound got a little more distant, which was nice but I got some distortion on loud passages. I would guess some over driving. Back to single amp use. Might be interesting to try the Protector and 71B.
Dec 29, 2010 at 9:56 AM Post #510 of 1,194
Sasaki
The build quality is the best as always. SR71B is thinner and better fit to iPod than SR71A.
I don't have balanced source so I hooked my usual iMod into SR71B. I use balanced Whiplash TWag/SCag with JH16. This is the same setup to my Predator.
Even if the source is not taken from balanced, I feel good amount of improvement from Predator. The expansive sound stage(rather I'd like to say sound space) is even larger than Predator. If I use word "wider" it would sound like 2D but I felt 3D like volume expansion so I used the word "larger". I think Quad-mono surely works here.
Actually this expansive sounding contributes the natural sound representation. Orchestral tracks now sounded like more realistic and life-like.
However I also feel I need a better source for this level of sound. So I am thinking to get Boomslang. Thanks to Jamato your info is helpful to create my sys-concept cable.
