Juaquin
- Nov 20, 2008
I've been doing some work with my little rotary encoder and I think I'm ready to order a couple prototypes. The main idea is the encoder input (with optional push-switch) and then outputting a count over the 1-wire protocol through the HEADER (which also carries 5V and GND) to an Arduino / LCDuino. There's also a breakout that contains most of the other pins, if people want to add more or modify the design, and of course the ISP header for programming. There's a resistor/cap combo to stabilize the reset, a cap on the power pin to stabilize that, and a small electrolytic to stabilize the rails since this may be a ways from the power source.
Here's the schematic and the board is below. It's not very polished - mostly just a working prototype to get it off the breadboard. If anyone feels so inclined, please look it over and let me know of any mistakes or problems. If there's nothing bad I'll order a couple to play with.
[EDIT] The encoder will be mounted on the other side, so it can be panel mounted. Also, the top plane polygon is 5V and the bottom is GND - sorry for the confusion, the capacitors/power pins ARE connected!
