Whazzzup
we don't speak of iTunes, although thats where i buy my tunes then copy and drop them on my antipode. And no iOS won't play flac, dsd....
Roon iOS app can play higher res than what Apple even allows themselves (with the right DAC). I'm using my Chord Mojo and playing 24bit 88.2kHz files just fine on the iPhone, streaming from what is essentially my Roon server (a desktop iMac). The only negative to this is the iMac must be left on.
Apple themselves only allows native play up to 48kHz files. I'm not even sure if Apple will allow you to copy over a higher bitrate file for storage on iOS.
I'm a n00b with Roon, but that was the easiest update of just about any software. Of course, now my IOS devices won't connect to my core now, so I have to figure that out. I had to specify the IP address manually anyway since my WAPs (eero) is configured in NAT mode and it's not passing on the discovery packets, but even that does seem to be working.1.4 out today. Lot of improvements, biggest for me is iOS playback!
Not sure where you got the impression that I thought it wasn’t cool. In fact I even stated it was cool...What?See, it's cooler than you initially thought!
You can certainly copy over higher res files to an IOS device, probably just not through itunes music. I use the Onkyo HF player and use itunes to transfer up to 192/24 flac files.
I don't really have a recommendation. I am using upsampling if only because it's the default setting. The only DAC I pair my iphone with is the cipher cable with my isine10 or 20. Otherwise, I'm normally using the internal apple DAC. So, it might make a bigger difference with other DACs.Semi related question- do you use/recommend up-sampling mode in the Onkyo app?
Does Roon play mqa files from tidal
So I've been thinking about trying Roon and probably will soon. A couple of questions, and please bear with me:
Does the new 1.4 where you can use an iphone as an endpoint mean that I can connect my Mojo to a pair of active speakers and connect an oldish iphone to the Mojo and then use my new iphone as a remote and stream wireless Tidal, iphone to iphone? My Roon Core would be an Asus PC.
And does this make the Poly (for arguments sake let's assume the Poly is everything it promises to be after the coming updates and app release) slightly redundant for streaming Tidal at home to active speakers?
Hope that makes sense...
