fredhubbard2
- Jun 18, 2015
Ah OK, just wasn't sure if it was mandatory or not...
If you have more than 2 sd cards it would make sense to put it on all of them.
System Volume Information will appear if you have inserted the card in X3, it is normal and X3 will automatically create a file known as "system volume information"
I personally have no idea on what it does.
Sorry, many q's as I work up to RBing this thing tonite:
As far as themes, are there only particular models' themes you can use ( for instance , only ones made for Sansa Clip) ?
Obviously non-album art friendly ones are needed.
the clip + ones were recommended . looking at the themes on RB site only clip and clip + are monochrome and therefore compatible ... you got 112 to choose from
Well I checked again, ensuring I had the hidden files visible option engaged, and NONE of my mSD cards have this extraneous file on them. All my cards (2x128Gb, 1x64Gb, 1x32Gb) were formated into FAT32 with guiformat.exe.
This viewing my cards in my xDuoo X3 while connected to my desktop via USB in the factory firmware mode.
Are there any equalizer pack files to download?
Translated by Google from Russian website http://player.ru/showthread.php?t=157050&page=184
: "In today's update (37373fd-160418) rokboksa:
- Added key lock and blanking of the screen (if configured) for 1s retention. Button Power. Turning off the Power button to retain for 4c .;
- calibrate the battery. Now charge interest should indicate more precisely. Also fixed charge only up to ~ 85% for some players;"
