greenleaves
- Oct 26, 2004
I believe this is where the Redwine mod could possibly make the SQ difference by physically changing the caps and other stuffs along the signal path up to the line-out. But that is a very different story altogether requiring hardware changes. Even so, the internal amp inside the Codec cannot be bypassed in the usual sense, and the iPod EQ reamins funtional in the line-out. I have a confirmation from Vinnie of Redwine in another post for the 4G mod in which he said:
Yes, you can still use the EQ, but I don't recommend it because it adds distortion. I always leave the EQ set to OFF.
Best regards,
Vinnie
Originally Posted by K2Grey While the DAC may indeed be handling the task of amplification, it's still not necessarily the case that Apple did not put caps or whatever in the signal path and so on. I really doubt it's a direct DAC - out connection. It'd probably be nice if someone could open up their iPod and post the components for both headphone and line out signal paths. |
Best regards,
Vinnie
