Rockbox for iBasso DX90 dual boot with Mango (Stock Firmware)
Apr 28, 2016 at 4:43 PM Post #1,246 of 1,316
Delete Option does not Show up in the context menu here and I dont know why .
But I found a better solution
- in Settings define WPS hotkey as delete
- Chose a theme where WPS hotkey is working
Took me a while but is comfortable for deleting files .
May 12, 2016 at 7:50 AM Post #1,250 of 1,316
I am a newcomer having used the DX90 with its stock player since I bought it. Now I just discovered Rockbox and I just put the current version of Rockbox on my DX90.
Great work on a great port Napka thanks!
May 18, 2016 at 9:44 PM Post #1,252 of 1,316
  Just curious... why'd you choose the DX90? Did you consider the newer DX80?
maybe being rockboxable is an excellent point for dx90, thanks to napka and everyone involved in its development.
maybe using replaceable battery is another good point for some people (carrying a pair of small 2100mAh batteries gives you about 6000mAh autonomy; batteries death is easy to manage: just buy a new one, no big research and soldering needed).
but sound quality or signature also might be decisive.
that's why i tried to locate a dx90 somewhere (being discontinued), at more expensive cost than dx80, a few months ago.
some sellers told me the same: "why not the newer dx80?", after ordering dx90 to them and discovering they actually had not real stock; this happened me twice.
newer doesn't always means better.
May 19, 2016 at 12:17 AM Post #1,253 of 1,316
Vouch for DX90. I found DX80 not interesting (sound-wise) for me. DX90 modded by SanMigel was good and comparable to full mods. I'm still waiting for DX90 it on aftermarket, but no luck yet.
May 21, 2016 at 7:13 AM Post #1,255 of 1,316
is the version of rockbox on the 1st page the latest version. also should i update my firmware to the latest ibasso version ??? not sure which version i have but it will be from over a year back now. i do have rockbox on but not really used it so won't know what version it is
May 22, 2016 at 3:08 AM Post #1,258 of 1,316
  DX90 Firmware v2.4.0 version lurker updates to L2, Can you update about rockbox version? Furthermore, the availability of source code rockbox
Thank you very much to pay
Source code's at rockbox.org. Some patches are in gerrit.
Jul 5, 2016 at 9:48 PM Post #1,260 of 1,316
Thank you very much napka
Firmware update to DX90 firmware v2.5.1 L3, the new feature is very useful: the folder can be directly added to the play list, you can also support the ISO file.
I hope you can double-click to start the firmware update
