pietro77
- Mar 8, 2015
You should try the batch tool from the first page on the DX90 page then reload your favorite fw.
I have done it already,without results...
As far I understand current version of rockbox is patched to disable second core. How I can enable that second core? I would like check is there will be difference...
At one point, the second core was enabled in one of the builds. The effect was negative to both system response and sound quality. It was quickly disabled and never enabled again.
