RugbyPlayer
- Jan 22, 2013
It was booting just straight into Rockbox. I tried it another 5 times and finally got it to boot into the standard player and didnt want to mess with it anymore so i rockbox out
Please version Rockbox & stock 2.1.5
Why? The only difference with the stock is the mod only removed none essential running process which takes CPU cycles and not needed by both Rockbox and Mango to play music.
in stock I've battery life > 8 h, mod < 7h (player is warmer)
Mango 2.1.5L have off scaling cpu?
FW 2.1.5 patched for Rockbox with Lurker's L1 mod.
Google Drive
DX90FW_V2.1.5_patched_with_Lurkers_L1_mod.zip
Mega
Boot into Mango and just flash the update.img as usual. No additional steps required. Rockbox should not be affected.
ok
I"ll check
Updated to latest dual boot firmware and Rockbox 2.1.5 a couple of days ago. Rockbox playback occasionally freezes randomly mid song (been trying to identify a pattern, nothing so far) then continues after 15-30 seconds. Track time usually skips backwards a few seconds as the playback resumes.
Anyone else experiencing this? I am running the "While Playing Screen" from the RedBox theme, everything else from the DriveBox theme, otherwise standard implementation.
My main motivation for running Rockbox on the DX90 is because I can't get enough bass for my liking from Mango for my Fidue a86 iems, currently running standard everything in Rockbox apart from +7db on the bass which is seems to be the sweet spot for my ears. if anyone cares to share some Mango eq settings that add a bit of extra punch I would probably leave Rockbox alone.
Edited to add that I am also getting about 6hrs off the stock battery via Rockbox.
