Rockbox for iBasso DX90 dual boot with Mango (Stock Firmware)
Discussion in 'Portable Source Gear' started by headwhacker, Jul 21, 2014.
7 8 9 10 11 12 13 14 15 16
18 19 20 21 22 23 24 25 26 27
  1. saratoga
    It wouldn't be too hard to add support for a DSF files (i think they're basically just a .WAV file containing DSD), but the filters required to decode DSD would be expensive enough that its probably a lot more efficient if you just convert to FLAC.  Files should be smaller too since FLAC is compressed.
  2. headwhacker
    New build available for download
    Rockbox_DX90_0_1_4.zip
    Change log
    04/08/2014 - Further tweaks to eliminate noise when changing tracks (fwd and back).
                       - Changed boot selector menu wallpaper.
  3. psychokite
    Just installed the latest version you made, but seems I have no choice to go to Mango.
    Rockbox is loaded directly, and a little cracking sound is appearing at the start!
    Any advice or did I do something wrong ?
    Thanks
    EDIT: my mistake, juste found the answer, as did not have the Hold button switched on.
  4. Alphonse
    [Request to developers]
    thank you correspondence to be able to play in 24bit 192k urgently rockbox.
    Value as a high-resolution player will no longer be in the down-conversion of 16bit 44.1 in of a player if there is Rocbox DX90.
    DX90 user rockbox for you been waiting a 24bit 192k correspondence.
    Thank you very much in advance.
  5. all999
    New build installed, crackling issue is gone. Thank You for your work, It's great!
    maciux likes this.
  6. hyper8
    Installed the new build. New menu selection screen is much better than previous. Crackling sound is also gone
  7. Migou67
    Installed also the latest build and no problem at all , thank a lot.
  8. deho
    The new build is working just fine for me. Thanks for the latest improvements, headwhacker. [​IMG]
  9. nmatheis Contributor
    For some reason I can't get the database to initialize with the new version - even after a factory reset.
    Edit: The problem is just with Rockbox. DX90 FW database is fine.
  10. Negataros
    Solved my problem, only issue is it stucks while scanning the database
  11. headwhacker
    Did you tell rockbox to to scan only /mnt/external_sd only? (Somewhere in the Settings > General > Database) Scanning will be stuck if you do not tell rockbox to scan only the sd card partition.
    I got a 128GB card full with ALAC files and never got any problems building the database.
  12. nmatheis Contributor
    Didn't need to do that with previous builds but will try.
  13. all999
    Still can hear a little crackling with 0.1.4. It's random now and no related to the track skip. Changes are going in right direction[​IMG]
  14. nmatheis Contributor
    Didn't help. Still hangs on initializing DB. Message says something like "XXXX files found. Building DB. Press OFF to return". This is the first build I've had this issue with and have resorted to just using file browsing.
  15. headwhacker
    Flash the previous build and initialize the database and see what happens.
