Is there any different between IBasso software player and Rockbox?
Purpose/benefit of it?
Sorry if i not geek enough, lol.
For me it is the complete combination of features which you would want in any advanced/expensive Digital Audio Player which surprisingly is not implemented as standard on any of the expensive brands - A & K, Apple(Apps give limited/singular features), Cowon etc.
Maybe they don't want to confuse their customers with too advanced settings or give customers the opportunity to ruin the sound signature or the $ goes into the hardware not the firmware.
Features like Parametric Equaliser, Compressor, Custom Stereo Width, Crossfeed used together & found nowhere else (unless in a physical & expensive home rig) make a for a superior sound.
The only things missing I can think of are the ability to add reverb if you like that but that can muddy the clarity, a way to monitor the sound signature colour-coded so you can tell whether your changes have caused clipping.
My concern is with the Sandisk Clip Zip being withdrawn & currently no other later Sandisk player being Rockboxable, iBasso DX50/90 is currently the only modern mainstay for the Rockbox Platform which is not deemed stable as it needs to be manually installed by those who know what they are doing.
I also concur with the unstable status, if I confuse my DX50 with too many tasks such as chopping & changing playlists while playing several tracks; it will freeze requiring a full reboot. It's workable because generally you leave the player running but it is still a bug.
