RockBox For HiFiman HM601 and for HM801
Dec 5, 2012 at 11:49 AM Post #347 of 364
Just got my HM601 Slim. Trying to figure out how to install Rockbox but i'm not sure what to do =/. How do i patch the original firmware? and where do i find the base.rkw file?
Dec 5, 2012 at 1:01 PM Post #348 of 364
Make sure, that the SLIM version is fully supported before installing RockBox or you may end up having an expensive paperweight. As I remember, the display on the slim version is different from the standard 601 (as well as the 602 and 801) which is the reason for this problem with the slim version of the 601.
Dec 5, 2012 at 2:07 PM Post #349 of 364
I guess i'll just talk to head-direct first before doing it.
Dec 5, 2012 at 2:29 PM Post #350 of 364
They will say the warranty is voided if you install RockBox I'm quite sure and also that they can't help you with third party software. Go to RockBox forum and ask there for advice.
Dec 5, 2012 at 5:05 PM Post #351 of 364
Just looked into it. Sadly...a stable version is currently not available for the slim versions.
Dec 19, 2012 at 11:20 PM Post #354 of 364
It works for me with approx 100gb filled on a 128gb card. Maybe you could ask for help on the rockbox forum:
http://forums.rockbox.org/index.php
Just install rockbox on my 801 but I can't get database working it get stuck on building database do I need to change some setting in rockbox to get it working or is there any other solution.
Feb 28, 2014 at 7:56 PM Post #356 of 364
No, I think you need to use USB connection. Beware that the internal memory won't be accessible after installing RockBox though. Make sure you know what you are doing before you install it - including how to uninstall it if something goes wrong.
Nov 19, 2014 at 5:54 AM Post #359 of 364
Check out the RockBox forum.
Mar 8, 2022 at 8:46 PM Post #360 of 364
What are the traps and pitfalls while installing the RockBox for HM601?
What should I bear in mind about it?
