karma
- Jul 21, 2004
No, the A900 doesn't change much with an amp. It's very easy to drive.
No, the same differences that I described previously still apply. The thing is that the Senns sound their best when amplified, whereas the ATs sound the way they sound regardless of amplification. Is an amplified 595 better than an ampless A900? I personally don't think so, they're just different as previously noted.
If you do get the 595, I would recommend an amp eventually when it is affordable for you. They'll be okay without one, but they do improve when amped. I don't think an amp for the A900 is worthwhile unless we're talking about the really expensive ones, which I've no experience with.
What do you mean by "cheap?" When I first started here, I thought a $50 amp was cheap. Now I'm about to drop $300 on one.
Originally Posted by NeedHeadphones I know the A900's don't need an amp but does it matter if you have one? |
Is a senn 595 with an amp way better then a A900 without an amp? Or is the A900 still better without one? |
If I do need an amp could you suggest a cheap but good one. |
