Right ear in AD700's keeps going out
Feb 9, 2010 at 6:55 PM Thread Starter Post #1 of 6
Mangudai
Two things I noticed that more than likely cause it to go out is if I listen to a song that is bass heavy or if I accidentally bump into something on the right side of the headphones. Sometimes it wont go all the way out it, the sound will drop about 25% but if I turn the volume really high it will go back to 100%. What would cause this, would you say the cord is loose? I was thinking to see if I could still return it to Audio Technica but if not, see if I could fix the cord.
Feb 9, 2010 at 7:18 PM Post #2 of 6
It's probably a loose connection. I'd exchange them if you can.
Feb 9, 2010 at 10:16 PM Post #4 of 6
^ I dont think the earpads on the AD700s can cause a volume difference. I played with the pads ALLOT and did not experience this.
I think its just a lose connection. If you have warranty I would exchance them. If not.. Just take them apart. The build is quite simple and easy to fix if you can handle a soldering iron.
Feb 10, 2010 at 12:54 AM Post #5 of 6
I just realized that the warranty was only for one year, for some reason I thought it was two. Guess I'll be going under the knife. I dont really know what to expect as ive never open any headphones, what is it that I have to do exactly?
Feb 10, 2010 at 4:24 AM Post #6 of 6
Took it apart and didnt see anything unusual aside from the thin black wire being exposed in a few places. I wondering if it could be ground out on something? When I have the time I'll add tiny pieces of electric tape to the exposed areas and see if that helps.
