Review: Woo Audio WA6 vs. WA6SE (stock units)
Oct 28, 2008 at 3:12 AM Post #16 of 508
takezo
the caps are 330uf/450v cdm caps with additional rubycon caps in smaller
capacities. wooaudio put in what looks like an additional filter stage, not sure
though since the voltage is only 16v, in the front section, as can be seen in
the second smaller pic...
here's some additional internal pics:
Oct 28, 2008 at 3:22 AM Post #17 of 508
atbglenn
Interesting. What are the purpose of the solid state rectifiers? DC for the 6de7 filaments?
Oct 28, 2008 at 3:27 AM Post #18 of 508
takezo
Oct 28, 2008 at 3:29 AM Post #19 of 508
atbglenn
bridge rectifiers possibly used to supply DC to the 6de7 filaments?
Oct 28, 2008 at 3:33 AM Post #20 of 508
takezo
hey john, how much of a factor does the resistor make between
the 2nd and 6th pin of the output tube? will a mills be preferred
over the vishay resistor wooaudio seems to be using?
Oct 28, 2008 at 3:35 AM Post #21 of 508
takezo
unless i'm very mistaken, there isn't any solid state rectifier in the pics...
Oct 28, 2008 at 3:38 AM Post #23 of 508
jamato8
They have gone dc on the heaters, which is what I did on the Woo 3. Some feel AC on the heaters is more dynamic but there are varying beliefs on that. I went DC even on my old balloon tube 27's. They can be quieter that way.
Oct 28, 2008 at 3:41 AM Post #24 of 508
jamato8
You want a very fine resistor there as the signal is going through it. A good carbon or an older tantalum, before they went to magnetic ends. Even on the 60,000 Audio Note dac they use good carbons so that is what I would use and do use now. I have some of the good tants but they are in storage but to be honest a Kiwame or Riken Ohm would be very fine. I am not crazy about metal film but there are a few good ones.
Oct 28, 2008 at 3:43 AM Post #25 of 508
atbglenn
ok so woo is using solid state rectification to supply the 6de7 filaments.
Oct 28, 2008 at 3:56 AM Post #27 of 508
atbglenn
ok guys, point it out to me... lol
Those filter caps at the rear are soldered to the DC side of the 2 rectifiers. (the square thingys)
Oct 28, 2008 at 3:56 AM Post #28 of 508
jamato8
See the two square devices with a cap soldered to them and they have a allen headed screw to hold them in place? those are bridge rectifiers.
Oct 28, 2008 at 4:05 AM Post #30 of 508
atbglenn
And I learned something too, they're devices, not thingys. LOL
