REVIEW: Vivo Xplay 3S + XE800 Mobile audio perfection
Feb 17, 2017 at 6:21 AM Post #631 of 682
Ruben123
I haven't found a right one. Usually from trrs to trs. One seller shows pic of trs to trrs but customer complaints he got it reversed. If there's a link that anyone can suggest please do. Sorry out of topic a little.
Any regular extension cable works, at least all 5 different ones I tried. At the time I bought them, I didn't know anything of tts etc. I'll get you a link but don't worry it'll probably just work fine
Feb 17, 2017 at 9:42 AM Post #632 of 682
fairx
Gin no Kuni, Malaysia
Thanks. I will dig out my old extension to test.
Back to xe800. I'm back at home and test with my old iPhone 4s. Sound a little thin and lifeless. Plug into my o2 on low gain and thing gets interesting. However the best sounding so far is with Fiio Q1 dac amp. The extensions and articulation are on different levels. Xe800 does scale very well with good source.
However coming from earbud I sense xe800 a little fatiguing. Maybe more burn in or brain adjusting needed. Not highs or mid fatigue but from bass fatigue. To others the bass might be normal or even lower in quantity but to me it's a little bit tiring. One more thing I can sense is that the vocal are little recessed. Not laid back, just recessed. Not by much but still noticeable.
I give it to couple of friend for audition and all of them really satisfied with the sound quality.
Mar 6, 2017 at 9:54 PM Post #637 of 682
bhazard
Finally got my own cheap XE800 delivered. First impressions.... it's been too long to remember the original XE800 sound I had years ago, but yes it is so similar that these are either genuine or nearly identical.
Not enough bass, and the upper mids sound a bit artificial, but still nice for the prices now. It's just hard to go back to this after trying something like the K3 or A4.
Mar 6, 2017 at 10:26 PM Post #638 of 682
snip3r77
Should not compare as there are more than $120
Mar 7, 2017 at 3:04 PM Post #639 of 682
bhazard
It is very much a valid comparison. The XE800 was $99 at launch.
In 2 years time, for $50-100 more you now get significantly better sound. At $15, these are an excellent choice for a clear but bass light signature, but it isn't something I enjoy anymore.
Mar 26, 2017 at 6:34 AM Post #640 of 682
Viber
SO... XE800 in retail box for 8$ , gotta be a fake right??
https://www.aliexpress.com/item/VIVO-3-5MM-flat-earphone-with-mic-and-control-white-color-in-ear-useful-Earplug-for/32796742405.html?spm=2114.01010208.3.2.yDpBbl&ws_ab_test=searchweb0_0,searchweb201602_6_10065_10068_433_434_10136_10137_10138_10060_9999_10062_10141_202_10056_10055_10054_10059_123_10531_10099_10530_10103_10102_10096_10052_10144_10053_10050_10107_10142_10051_10106_10143_10526_10529_10084_10083_10119_10080_10082_10081_10110_10111_10112_10113_10114_10078_10079_10073_10070_10122_10123_10120_10124-9999_10120,searchweb201603_7,afswitch_1_afChannel,ppcSwitch_5,single_sort_0_price_asc&btsid=f090b8b0-5ea0-4636-9db9-65d981ef81a1&algo_expid=536a3e7e-fc1a-4393-9964-341d8fdbd304-0&algo_pvid=536a3e7e-fc1a-4393-9964-341d8fdbd304
May 17, 2017 at 10:39 PM Post #645 of 682
jatergb
From the current listings on AE, other than the Rillpac store, has anybody purchased from any of the 3 other stores? My friend liked the quality and didn't want to ask it back. I want another pair because i just love the SS. :)
