REVIEW: Vivo Xplay 3S + XE800 Mobile audio perfection
- Thread starter bhazard
bhazard
- Jul 15, 2013
You'll love it. High quality audio at bargain pricing.
fyu
- Jun 17, 2008
Would you say these are comfortable enough to sleep in?
I'm not going to sleep with them on, but I am looking for extremely comfortable IEMs that I can use daily for several hours.
nehcrow
- Jul 1, 2010
So I'm guessing these have slightly less bass than the GR07BE? Damn.
I thought the GR07 MK2 was a bit bass-light for me, GR07BE seemed to be pretty close to ideal in quantity
SkiesOfAzel
- Aug 13, 2010
I worry about the opposite, the GR07 with a good seal sound to me like it has a few db more bass than neutral. If the XE800 has considerably more bass it might be too much for me.
raisedbywolves
- Feb 12, 2009
these sound really good. just curious, if i order through mistertaobao and choose singapore post, what is the likelihood i'd get them by the 25th? high? not too high? if it's fairly high i'll pull the trigger right now.
kahaluu
It's going to be really close. If you definitely need them by the 25th, I wouldn't pull the trigger.
SkiesOfAzel
- Aug 13, 2010
The only way to make this high is through the use of illegal substances. Mistertao can't ship the product immediately, he has to order it, receive it and then post it. Add 14 working days for it to ship to you and you have your answer. Sorry mate.
raisedbywolves
- Feb 12, 2009
argh. i need a pair for the airplane on the 26th because my re-400's are almost dead and i don't think my aurisonics rockets will be here by the 25th so i'm trying to figure out a good option. i suppose i could just go with some vsd3s's or something then sell them on here once i get the rockets.
raisedbywolves
- Feb 12, 2009
ah, alright. would it be possible if i ordered it directly through taobao instead of mistertao or still highly unlikely?
SkiesOfAzel
- Aug 13, 2010
I don't know, I am not even sure tabao ships outside of China. Bit to be honest, even if they do, it's still unlikely you will get it in time
Nice review!
Subbed!
Subbed!
raisedbywolves
- Feb 12, 2009
yeah, i wasn't sure whether or not they did but you're probably right. i guess i'll have to look into some other alternatives then.
