NeonHD
This iem cost me 6$ and with right music they have the amazing highs right after obravo eamt 2c
What!!! $6???? They're that cheap now? I bought three of them back when they were still priced around US $25, damn...
P.S. Do most people here listen to their MH1C unmodded? Cause the main reason why I ditched the MH1C was that the sound was too mellow and lacking energy, but then after completely removing the mesh filters on my third pair, it was like breathing life into the MH1C again. High-mids and lower to mid treble both became much more emphasized, and thus clarity was improved drastically. Vocals are now soooo incredibly clear and defined. The bass is also drastically reduced, only to be summoned when absolutely needed in tracks. The difference between modded vs unmodded MH1C was day and night. Just remember to use foam tips as they help tame the added sibilance of the mod. Heck, I don't even hear any harshness in their sound with stock eartips anymore (either cuz brain burn-in or the actual driver "retuning" itself).
This was my horribly amateur attempt at analyzing the FR curve of the modded (mesh-removed) MH1C:
Usually you'll find the main peak at 3Khz, but now it's shifted over to 6khz.
I think they sound perfect unmodded. I much prefer them to my hd6xx's.P.S. Do most people here listen to their MH1C unmodded? Cause the main reason why I ditched the MH1C was that the sound was too mellow and lacking energy, but then after completely removing the mesh filters on my third pair, it was like breathing life into the MH1C again. High-mids and lower to mid treble both became much more emphasized, and thus clarity was improved drastically. Vocals are now soooo incredibly clear and defined. The bass is also drastically reduced, only to be summoned when absolutely needed in tracks. The difference between modded vs unmodded MH1C was day and night. Just remember to use foam tips as they help tame the added sibilance of the mod. Heck, I don't even hear any harshness in their sound with stock eartips anymore (either cuz brain burn-in or the actual driver "retuning" itself).
Have tried with the mesh removed, and on Tool - Parabola, for example, the bass is non existent. Sound much better without any modification with rock/metal.This was my horribly amateur attempt at analyzing the FR curve of the modded (mesh-removed) MH1C:
I just tried the mod and tend to agree. I tend to prefer them unmodded because I prefer a warmer sound signature. But I do see why some people would prefer them modded.Have tried with the mesh removed, and on Tool - Parabola, for example, the bass is non existent. Sound much better without any modification with rock/metal.
I know this is a really late reply, but I've seen a lot of people displeased with the original MH1C cable and put a lot of work into recabling it. If you run the cable under a shirt with a collar, the section with the microphone/buttons can be hooked over your shirt collar, which prevents the weight of the cable from pulling on the tips. Also, the original cables have minimal microphonics, and running the cable under a shirt further reduces any microphonics. I actually really like the cables, and think it's just a matter of wearing them a certain way.I am working on a recable stuff for this IEM and I think I would share how I can do it. Currently, I am waiting for the cable to arrive.
Not tested the sound, I listen to music a lot but tI am not an audiophile, so I will not concentrate on the sound changing. You may try and see what is changed.
What you need:
- 3x3cm Acrylic glass (Mica). If you can find a thick Mica panel (1cm, that would be awesome)
- A drill with 2 drill bits size: 3mm for cable and 5mm for housing.
- Sand paper
- Saw (whatever kind)
- Super glue
They look better outside. Images look terrible
Steps with layout image below:
- Remove the old cable, only keep the metal housing. There are many threads show how to remove it.
- Cut the acrylic panel to (1x 3cm) x 2 pieces if the thick is less than 0.5cm. One piece if the thick is around 1cm.
- Use super glue to glue 2 cut acrylic panel to one. If you do it correctly, they will look like 1 piece of glass . If your acrylic panel has 1cm thick, no need to glue 2 piece, one piece is fine.
- Use sand panel to make it round shaped heads.
- Cut the acrylic piece into two pieces.
- Drill holes for housing and wires
- Make rings to plugin the housing. This step is important. You have to sand and try it with the housing to make sure the ring is not too small to the housing.
- Finally, polishing the parts, make the parts look better.
- Wiring. Maybe you can make the under hole bigger so you can use the MMCX.
- Test the sound?
And for what folks in New Orleans call Lagnaippe: after years of using these, I can't stress how well they pair with Shure olives/black foam sleeves (https://www.head-fi.org/threads/review-sony-mh1-–-the-best-kept-secret.632892/page-234#post-12032045). Great sound, mimimal occlusion effect/bone conduction, and pretty amazing noise isolation (as good or better than Etys, minus the really bad cable microphonics).
I just upgraded to a Galaxy S10+, and am quite pleased with the combination. The microphone consistently works, they sound pretty good with Poweramp, and three of the four buttons work with Poweramp. I occasionally look around for a better smartphone headset in terms of utility and sound quality, but haven't found one. As a result, I feel like the title of this forum thread still applies some seven years from its inception.
Don't forget kova4a's tape mode - it really helps a lot https://www.head-fi.org/threads/review-sony-mh1-–-the-best-kept-secret.632892/page-32#post-8835261I know this is a really late reply, but I've seen a lot of people displeased with the original MH1C cable and put a lot of work into recabling it. If you run the cable under a shirt with a collar, the section with the microphone/buttons can be hooked over your shirt collar, which prevents the weight of the cable from pulling on the tips. Also, the original cables have minimal microphonics, and running the cable under a shirt further reduces any microphonics. I actually really like the cables, and think it's just a matter of wearing them a certain way.
And for what folks in New Orleans call Lagnaippe: after years of using these, I can't stress how well they pair with Shure olives/black foam sleeves (https://www.head-fi.org/threads/review-sony-mh1-–-the-best-kept-secret.632892/page-234#post-12032045). Great sound, mimimal occlusion effect/bone conduction, and pretty amazing noise isolation (as good or better than Etys, and without the really bad cable microphonics).
Sorry, I should have specified that the cable is supposed to be worn behind the neck. I also got annoyed with fitting them in a small case and switched to using a zippered coin purse to store them.I think they were originally meant to be worn behind the neck. This way you can take your earphones out and hang them on your chest. Good for workouts, etc. But the issue for me was less the J shape and more the flat cables. They are obnoxious to roll up into a small case.
