[REVIEW] Sony MH1 – The Best Kept Secret
Feb 24, 2019 at 11:16 AM Post #3,707 of 3,824
Aha! It’s good to see the frequency response of a unicorn next to a typical sample. The comparison Rin Choi provided years ago suggested that it’s the bass that’s the problem with the bad ones.
... snip
Don't hide those graphs behind spoilers, thats a really awesome analysis and mod! I'll try it out, as soon as I'm done enjoying the mmcx mod on my mh755s (actually that might take a while) :D
Thanks for that amazing mh755 review btw, they're seem so easy to (re)cable without messing up their response.
Edit: just for reference, pinhole mod by Sead is described in this post: https://www.head-fi.org/threads/sony-mh1-r-d-story-and-discussion.634193/page-6#post-8843651 ; remember to remove the mesh and place it on a flat surface before using the pin on it, otherwise you risk making too big of a hole.
Feb 26, 2019 at 9:41 AM Post #3,710 of 3,824
@yuriv which tips did you use with the Crescent? I found that most non-stock tips make the peak more pronounced.
Either that or they didn't make much of a difference. A foam tip obviously changes things because they absorb more sound and damp the resonance, much like room acoustic treatments. Only the room is much smaller and the frequencies much higher. Is the principle the same? You be the judge. Insertion depth also makes a difference, so a small silicone tip like the small MH1 tip might allow deeper insertion. It could push the resonance away from the problem frequency and also help fill in the dip in the response at 10-12k. I was going to post measurements, but there's a more appropriate place for Moondrop Crescent related stuff: https://www.head-fi.org/showcase/moondrop-crescent.23589/reviews#review-21671
Mar 3, 2019 at 12:10 AM Post #3,714 of 3,824
I am working on a recable stuff for this IEM and I think I would share how I can do it. Currently, I am waiting for the cable to arrive.
Not tested the sound, I listen to music a lot but tI am not an audiophile, so I will not concentrate on the sound changing. You may try and see what is changed.
xSpAmq3ASyYjSYYxTaEzBtRllRaIuQZUCg-iIfCW9q2ybMoarno-WuP6D6q5QAMtRitipe4DhU7MLDL7Hv_2SYmv3xV8OW9sDvelcGXrvQbc_AQeL8fp3_Zzdg0hZ0bAmJ6EfSi7Bl3Pbbt1KtusHU3Qpo9FZovREb9O3auaNPHE9REvUUGcmI2Ndm6J_HZM_i8F7OEBLMADn9xn-H-z0LBeud-wLkHE6WFDgkd5lF2Lb0MLuUkAUk78wwfhmkVoXhtt_Zb1_DEN2AZ6kpvPW5SVb8ACm0C0l6Eoo2pXS8st3mpZZARnKIv1JM9ERwHZeyQT2jA6mStcEv7vV6LzlKqqKGbIQLwRAlkRaOtKnriJ-zMsDdB2wtqSpM0byuX0yT9Ioo2cKcgZfjAxIgk_AsDnvf6lJdpC-sApocy60RyimqS3S7zDGJjL2bSMST4g1fZ3g4napJsU8pnCaiFLax059vomJud4U8myO9ml5oGBIZOQqP7x98H5McNaXumqp-T5m54SjS8kUP3xM6Z6xl0f29d3XrdKScjsC_ABUQQ9h_-awuHbFvUENWCOn5W9xHcuMqNfW5pxV2WTxSk0pZg2nh-4Y9_db1K047x_l3ZlFqjUsDCE3LpUEuWtA-xxX3jdkBGWytjHTaydCgWbkTVLFjd5M8o=w1263-h947-no
EWDUZ1z62UEhOyRFcDIYXecWWfso06aUI99BoesBFf_WOjjgGYzFNL5C8FQuV-dk2KXKg7cIlTDn1-3zy91z5binJzka03RjmS6Ru3sedcskSO6XKAbLA-T5MUC-48BFRDWZTgHBEjTntjo6J5FtnATCgI7o3WOpH91AjJ5FW-H56f-UXVyyxH03rzWLMKSCwX3CCKK2p2GY2tr0AuhdtvPba9CoRNBQXcKddV6Xt69TPGlAeMLRj9xquKb2uQXS4sg8SYmvilYzI_NVvPQa4Q7ucoEX68F_AYKMk4CHyBhVxsy_djxDTOozdEnfqd4DT1ewLPCKNQDca-h9bZrwrkqMXr4stlc32PFhJoMg-PC94JwUkwik1qKShMYv1xOjwBvZ3FjyKEQKo_Ag1GA7puhs2jKKB7ek3RMojA_xK4gU_7M7WlGD3mSVEcHmVvKqILejKsLNnzuTZr-xwlvxpupXYZO8pVv8PO9u64Td8aE-xf1mQaBpwHvPKZAFZtVPt_xISCOKnSTyZybGiJcnTADnMFRQtTXywntaen3Pk0autyhJV_krHi6P7WiDLt3Vwrupp-K8srqPfdBkbKxseXSOV-xngRPd2ZIrEPYvYFmp---PRWljbCrVVwInsDYQhFBIc2Lw0_cnxDVo-34R7_jyXRgeVbc=w1263-h947-no
VySVZWaFGYDRgccW3EJsylykStYGlR4Px2vJRsBx64ftLNo4TRCo1uLymZG2jIUx-gm0YcQDDo70XmHhJaeinxK6Lg1VrHCswZB8ZD6FLPPqWTI9Mv3bIkT7rGIsUQ7v_TRMOyeTv1jU6sI0k8e5qvtUnMCIBl_Lzoc2Bt0o3yuM5liCCV_YVuWaW44vVcPHxLp9hrvPok6u_WS1bizAUE0Ln0qyRzuE1wwXgGo8IjYFrn8TXKYKswfjFBz1KCYDXMZkMZODYN1cXwXQeipRLTaiySThwYvcqbzIN89ZDwdO7jOO9bS-J4cZmlkYVORliLdTlnY_IyN-xCqRDSEcvHllZSEOkUCv9Aw4WQCYWkiq2bB3jlng9-UDahv3NZguyx3WCgnKBOlBGyCec-l4fs0DHS1COvwIvoN2VfBKznj6wE2HBhftR2xywk5ejltliEg_chYXUC819DdqKyD0jkHB0h5nVXd9PPbXi3xAULPlOfed48bzT63ErxPFk3VB1unk9n-n2GChwFlAAj3FyKwWRRPjP2FYPeMc9nIm0jHl5y0ctfwz8-Xut2PPQWkhOovILSh5fo8ZE0UWEWS24glimyXtgxIvw_uI4k4tUKTUIQy8PGdKbv30rlzz_3NncphHIoubozfN5xD_ZkueKErTl-7Os5I=w1263-h947-no
LI47lLwaeO-u_8oAK95C80vSi9meynw6IfQ5lpBD7aCEPgXM5ePEyJqY7iIvHR1gkh-jFd6kGFkyMn9Mz_sv77NBPpGiEtKzrC4D_HJkXY7kn4842nevgLTiKVGsPU4NSjsfP8FLfvwYPQtaoeIkGc8Xx-b5rkRfeFk3iGfzKazAnEjlh77Ki_DUw5kpmqNjXaoH7waOVnnuWE8hsJZT93IjYNoRtpQyxKutQ5qKqDWjTM7mZNgpdOMPRPF_jLbKeCNjDdQoiSI-iBmGfXkbzZJJY9k6Ev1OW1kyuMDa4ueK6fEFRXmfKzvtXQJizsDiCTLkKya4briIoRqUj8B0Cb6AGGn7YVElRILPNMhXJPitKfw95bUHhC8w2AbI5IEeW_XrjxyUAU4qCh-7TEN6l-iYp5w-KpoDtldP-Pb02Jf5BfJ6PeUaAt64wTtp8p-Fmi5SpXr0uLLBp2YUVi_QrecqxicOtVG2JVK7av-MC-dSWXrC3_cyl-2vj-J1hKulurc4gI-cBK-9vC07-FaifjBtOYvTFln4UkCItAbBEInWj-OoRjEg3bxcQFBQ8HU-49t77wgvMLLO1R7jrG7kHl1HAV79QsK-LGJCFzMhuLNfPWlb_Za15prlA06x8aQtfR97qZr-fXjM0AH-CfeMduZCVhBVDoQ=w1263-h947-no
What you need:
- 3x3cm Acrylic glass (Mica). If you can find a thick Mica panel (1cm, that would be awesome)
- A drill with 2 drill bits size: 3mm for cable and 5mm for housing.
- Sand paper
- Saw (whatever kind)
- Super glue
They look better outside. Images look terrible :)
Steps with layout image below:
  1. Remove the old cable, only keep the metal housing. There are many threads show how to remove it.
  2. Cut the acrylic panel to (1x 3cm) x 2 pieces if the thick is less than 0.5cm. One piece if the thick is around 1cm.
  3. Use super glue to glue 2 cut acrylic panel to one. If you do it correctly, they will look like 1 piece of glass :). If your acrylic panel has 1cm thick, no need to glue 2 piece, one piece is fine.
  4. Use sand panel to make it round shaped heads.
  5. Cut the acrylic piece into two pieces.
  6. Drill holes for housing and wires
  7. Make rings to plugin the housing. This step is important. You have to sand and try it with the housing to make sure the ring is not too small to the housing.
  8. Finally, polishing the parts, make the parts look better.
  9. Wiring. Maybe you can make the under hole bigger so you can use the MMCX.
  10. Test the sound?
ukvg0vv2217O8huz1A91VMYzbqT5U2usUcfcG2ydbo2d8sZ_3GdbqCdI8WqRtDzGjs66Y3jqL-P8QSGhSDmYLoLUcxHBH9eOGxzqCteAZdZSvp1q5HBrgRYMmE25DKRpEpdBUm_ucWhvrKz9xsG1Ql7cpgrgbcS0XQCZRgsougUGckFhT3yQxmFOllBiGVAREvMdBNmEuma-e8KqGb4Wl7kgDyBS9ttoQ3dGkZnRUB7gR4Xs2-aO6tHRKYjsh4Bf-2CA2lfvU6-rqOvN8-PFnSLcBWlkOMD--_9DSHEH6iiDVgkPqfTEc7cF208kWaYtXo9k5Jj9tsiKomnfmo_8MDSwsgaZfZWHXoNjmwUQpMbkaUIbjmcT-oYC7FFiVrk2EY4uEhsymmc4xxWSZcNq1KGhRQIa3DAhCnLE8HcQe7VXPLPTO4Li9GKxo90QT_x3QZEtd1jiER-twLPQFb0y5EDWCU8tbbDOk0Bc4TeIUkHc_Z2IgdHehqdVm3VNiuuBQ5qZ868I7rj0zLipD339QzLcgq6e0ilAwFnvzUdTGYONsofG0mYkOISwHtRxVe3JTT2LHmDQLmjHkC4gf_gftcCr4Qh0bYQv2eukiR4tmZQkB87qIM_2S5MfuHVKF2FcfINgtscljm8vFN8W517oS31xzhUiEAI=w955-h947-no
Mar 3, 2019 at 8:31 AM Post #3,715 of 3,824
You should at least make sure they are working correctly before you start. After, it is really important to make sure they are in phase.
Mar 3, 2019 at 8:41 AM Post #3,716 of 3,824
Ya, but probably it should work fine. This just change the back cover of the earphone. When I looked at the back cover of the original one, it's sealed so you can fill the hole with glue after wired. This will seal the earphone, just like we close then upper ven of the original earphone.
As I said, the sound MAYBE changed, I just provide a tutorial how I can recable it :)
Mar 22, 2019 at 10:20 PM Post #3,718 of 3,824
Right when MH1 ‘LiveSound’ was first announced over a year ago by Sony Ericsson (*now ‘Sony Mobile’, after Ericsson sold its share of the company to Sony early this year), I wasn’t really paying much attention to it – Why wouldn’t I, or any audiophiles in that matter? After all, it is just a “headset” by the company’s smartphone division in Eupore, not from the famed headphone team in their Japan HQ. The bias kicked in and soon I have forgotten all about it. Fast forward to a couple of months ago, I was offered a chance to review the recently released Sony Bluetooth headset for Android, the MW1 ‘Smart Wireless Headset pro’, and find myself very impressed by the sound quality of - not only the BT unit itself, but also the IEM it bundled with. It turns out to be the shorten version of MH1 adapted for the BT headset. I immediately know it is an IEM that deserved to be reviewed as a standalone product before I can review the MW1. It will help to complete the story of MW1, and really give credit to the EU team that developed the excellent sounding headset.
[COLOR=FF00AA][UPDATE][/COLOR] MW1 review can be found here.
Sony Ericsson MH1 in bulk packaging from DX.
Spec
Driver: Closed 5.8mm dynamic transducer
Nominal Impedance: 15Ω
Frequency response: 1Hz-20kHz
Max input power: 67mW
Bass sensitivity: 125dB/V @ 40Hz
Mids sensitivity: 115dB/V @ 1kHz
For Android smartphone:
Music controls: play,pause, next/previous track
Volume control: up/down
Accessories and Build Quality
Normally I’ll start by talking about the packaging in this section of the review, but since I didn’t receive the full retail packaging, I thought we will skip that part. Accessories wise, you will get a shirt clip and 4 pairs of silicone single flange eartips (S, 2xM, L).
The IEM comes with 4mm wide flat cable in asymmetrical length (J-cord), and the Y-splitter is made in such way that cable must be looped behind the neck. While the cable itself is indeed durable and tangle-free as advertised, it is also a bit cumbersome and microphonics – good thing that the shirt clip helps to manage the issue to an acceptable level, but they are not completely gone. It would have been much better if it uses the smaller and oval flat cable found on Sony’s own XBA series of IEM. The cable is basically the only real complaint I have against the MH1, otherwise I would have been absolutely happy with it.
The included eartips are an improved version of Sony’s own Hybrid style silicone eartips that first appeared on EX700 and still used on the latest XBA series. The bore is just a tiny bit wider which results in lesser hinder on sound transmission while the flange has been extended for a more secured fit. Like the original Hybrid, these should have been sold separately as accessories as well, but unfortunately they are not.
Just 3 inches (or 75mm) underneath the left earpiece is the remote and mic. It has volume control as well as play/pause button (or to receive and hang up call) that should work with most of the current Android smartphone and tablet (*see next section for more detail). There is also an extra ‘smart’ button for assigning extra function, but unfortunately it only works with Sony own Xperia series of smartphone.
MH1 LiveSound (top) and MH1C Smart Headset (bottom)
Variation and Confusion
Bear with me here in this section as it is quite important if you are interested in getting a MH1. Let’s begin by explaining two standards used in making the 3.5mm TRRS plug on headset – OMTP and CTIA (both are organizations for mobile standards). For OMTP, the TRRS plug is wired as [Left-Right-Mic-Ground] (from tip-to-sleeve); for CTIA, the TRRS is wired as [Left-Right-Ground-Mic]. Since OMTP was initially endorsed by Ericsson (and Nokia, which still uses the OMTP standard), all of their cellphone, including those under the Sony Ericsson branding, uses this standard. It also got adopted by a few other cellphone manufacturers as standard before mid 2011, such as LG, Motorola, Sony and Samsung. In mid 2010, the OMTP organization transitioned itself into another organization (the WAC, if you are interest to know), and the OMTP standard for headset was subsequently being phased out by most manufacturers within the following year (* it takes time to sell off old models) in favor of the CTIA standard. Part of the big reason for adapting the CTIA standard might be due to the fact that it is the standard used by Apple on their iDevice, which represent a big share of the headset market. Standardization demands from political groups (i.e. the EU) also played a role to push for one headset standard that will work on both Android and iOS, as well as most dumbphones (except for Nokia, which doesn’t like to play with other for now).
Now that we have learned about the two standards, let talks more specifically in MH1. When MH1 was first announced, it was named ‘LiveSound’ under the Sony Ericsson brand and complied with the old OMTP standard. But when Sony bought out Ericssion’s share of the company and began to introduce their own Sony Xperia brand of Android smarphone, they start to adapt the CTIA standard on all their headsets. The new MH1 (*referred as MH1C, ’C’ is short for ‘CTIA’ presumably) is then renamed as ‘Smart Headset’ to differentiate itself from the old ‘LiveSound’ version. It was supposed to be a fairly easy and clean transition, but unfortunately it isn’t. Some of the new MH1(C) with CTIA wiring is still being sold on various part of the world under the ‘LiveSound’ moniker while other parts of the world already use the new ‘Smart Headset’ moniker. One thing for sure, if you see a MH1 with an old Sony Ericsson logo on the side, it is the OMTP version and not compatible to the newer Android smartphone. If it only has Sony logo stamped on the side, and being referred as ‘smart headset’ or with model name MH1C, then likely it is the new CTIA version. However, the only sure-fire way is to check with the seller for compatibility. In the event that you have acquired the wrong version for your cellphone, don’t despair – an inexpensive TRRS smart adapter will allow OTMP headset to work on a CTIA cellphone (and vice versa). This is by far one of the smallest I have found, and has pretty good build quality: Here.
MH1 and MH1C is close to identical on the outside.
Last few notes on this topic: (1) CTIA plug is compatible to almost all typical 3.5mm TRS socket, meaning you should be able to use the headset as typical IEM on any mp3 player (i.e. iPod, Cowon, Sansa Clip, etc). OMTP plug on the other is not compatible to most 3.5mm TRS socket and only sound normal with the TRRS smart adapter mentioned before or when you pressed the call button on the remote. (2) Given Apple iDevice also use the CTIA standard, you can use the MH1C on any iDevices as well, but the volume control and smart button won’t work. Only the call button is functional. [COLOR=FF00AA][UPDATE 30th Oct. 2012][/COLOR] I just got my Nano 7G and can confirm the mic won't work on it. Given I have tested the mic on my Nano 4G and it works, the current conclusion is - MH1 will likely work only on older iDevices but not the latest generation. Apple must have changed something along the way...[COLOR=FF00AA] [UPDATE again][/COLOR] As I was playing around all the different headset I have to figure out just which headset works with Nano 7G (and possibly iPhone 5) and which isn't, I stumble upon a solution to let MH1's mic and call button to work with Nano 7G and it is quite simple - it seems what Apple has done in the recent generation of iDevice is they have changed the resistance inside the remote that needs to trigger the mic and call button function, thus making some headset work while other won't. So how do we trigger the mic and call button function on MH1 (and likely on other headset that current don't work with the latest iDevice)? Easy, just press either Volume+ or Volume- button when you plug the headset in and release it when plugged in. The volume control still won't work, but it will give you the ability to answer call and play/pause music (single press), skip to next song (double press), back to previous song (triple press), voice over (long hold) and voice memo recording.
Just for fun, I ordered a pair of MH1C from DealExtreme and see if it is legitimate or not (*I also have the real MH1C sample directly from Sony). It turns out to be the real deal and it is the newer CTIA version as well. From the lack of packaging however, I’ll say they were probably taken from a full retail Xperia smartphone package (*some of the higher end Xperia smartphone come with MH1 as stock) and sold as a standalone product. Still, given I only paid less than $30 for a pair (retail is around $80), I’ll say it is well worth it. However, do note that even though I have received a real MH1C, it doesn’t mean you will too. Similarly, you can find a lot of ‘bulk’ deal of MH1 / MH1C on eBay, which may or may not be the real stuff. So buy it at your own risk.
Sound Quality
The IEM was given over 50 hours of burn-in before the review. At first, the bass can be a bit boomy while the presentation is more upfront than it should. In time, bass will settle down and the sense of space will improve. I do recommend a minimum 50 hours of burn-in (100 hours if you can) with MH1, but it is not mandatory. The IEM will sound good out-of-the-box - burn-in just tightens up the overall presentation and resolution.
The overall sound signature of MH1 is warm and sweet, while well balanced in all frequencies. Bass extends down to 10Hz and hits with really good quantity and quality. Not the fastest or biggest impact around, but nothing to be ashamed of even among bass monster. Mid is sweet and right in the butter zone to give the right balance of intimacy and texture while still maintains a good sense of layer and space. Treble extends up to the very top, but it is more about smoothness than it is brightness. While analytical listeners might not find the sparkle or crispiness to be enough for their taste, it still however compliments the mid and bass impeccably and doesn’t feel lacking in anyway. Soundstage is rather good. By no mean the best of the best or endlessly large, it does portrait width and depth in a very 3D, well layered and resolving manner within its own confine.
What I have noticed as I listened to MH1 during the course of evaluation is that this is an IEM that truly has bare minimum weakness in overall tuning. In fact, it excels in almost any genre I can throw at it – Pop, Alternative Rock, Vocal, Folk, Country, and even Classical – just name it. Granted it might not be the best at every genre, I will say it has some of the most consistent performance across the board… Okay, may be Electronic can use a bit more sparkles, but that’s about it - and it is not to say Electronic isn’t enjoyable on MH1 at all.
MH1 LiveSound (left) and MH1C Smart Headset (right)
Verdict
As I have mentioned before, the only complain I have with MH1 is its cable. I just wish that it was less awkward, which would have made the IEM a smashing success. Beyond that, it is a fully capable IEM that can actually compete easily with IEM that cost 3 times its original price, right at the edge of top-tier category. Even Sony’s own XBA-4 is not that far ahead of MH1. If you are like me, please put aside your bias against headset and give this a try. If you can get a real MH1 with those $30 bulk deals, it would be an absolute steal – much like the craze over ADDIEM (Apple dual driver IEM) a few years ago, except this is much better sounding and an even bigger bang for the bucks. I’ll wholeheartedly recommend it with a Sonic Diamond [4.95 / 5].
*A big thanks to Sony Mobile for the MH1C sample.
[COLOR=FF00AA][UPDATE Nov. 6th, 2012][/COLOR]
Another blogger is calling me a shill (indirectly) and provided some measurement to prove his points. While I don't agree with him - for all fairness, please give it a read as well: LINK.
[UPDATE Feb. 8th 2013]
Now hopefully all the fuzz about shilling is behind us. Read this.
A full win over GR02 Bass Edition, but I have not heard FX40. But given I have FXD80 and FXT90 (which is the 3th and 4th in JVC line-up), I will say I do prefer MH1 more.
Also, I get a semi-confirmation from my Sony source that all of these MH1 / MH1C floating around the internet in bulk package are likely to be all real.
The reasons are two folds: First, the original MH1 LiveSound, though excellent sounding, was never considered by the management as an audiophiles product, nor as it marketed heavily. So there are quite a bit of leftover stock after the transition from Sony Ericsson to Sony Mobile (and OTMP to CTIA) and they all get dumped into the market at much cheaper price in bulk package, intended as a quick sale to user who still own an OMTP cellphone, before they switch to the newer CTIA cellphone. As for why there is also a lot of the new MH1C floating around as well - it is due to the fact that management decided recently that they don't want to include MH1C in most of their Xperia, which causes an over-production, and so these are also getting dumped into the market in quantity too. Secondly, MH1 was designed to be hard to copy as it uses expensive parts for production, as part of their counter measure against copycat. It wasn't intended to be sold as cheaply during the original R&D but they find a way to cut down production cost by manufacturing in big quantity, which somehow back fired because of order from higher power.
The tale of a company's unfortunate being the customer's blessing? :wink:
great review. Was going to use mh1c with headphone amp. I'm a little slow (lol) but can I use mh1c with a standard 1/4 inch adapter?
Mar 22, 2019 at 10:23 PM Post #3,719 of 3,824
Sure. MH1C (which should be CTIA compatible) will work with 1/4 inch adapter like a normal earphone.
