Review: Sony MDR-7550
post-10256588
Post #121 of 250
kimvictor
I think I read it somewhere, or it could be just my imagination, I've read so many posts they are all starting to look the same... :blink:   but can the 7550 cable be interchanged with the ex1000 cable?  I've tried to see if I could tell from the pictures, but I can't tell.  I've read some posts that say the stock cable is on the thin side while the ex1000 is a bit thicker.  Also to keep on discussion, I ordered some complys for my 7550s that get here tomorrow. :bigsmile_face:   I could never get a good seal with the silicone tips, so comply for me. However I am a bit interested in those stock sony foam tips that i've heard about...
Im pretty sure that the cables are interchangeable. The sony hybrid tips are pretty good, but comply are better imo
post-10256631
Post #122 of 250
jww187
Charlotte, NC
Charlotte, NC
I had wondered the same thing or if any custom cable were available.  I also had looked, with no luck, if you could buy the connectors so I could play around with making my own.....if only I had all the time to play with my earphones that I'd like.
Anyway, I had came across this listing.  Makes me think they are the same, but I've never seen anything else to say one way or the other.
http://www.head-fi.org/t/652676/sony-ex1000-ex800-7550-600-silver-cables-chris-himself-free-shipping
post-10256660
Post #123 of 250
syobwoc
that's good to hear, i've never had a bad time with complys.  i'll probably just stick with them. Thanks!
post-10257875
Post #124 of 250
kimvictor
Custom-iem.com also has custom cables for EX1000, which I think should fit the 7550. Ask chrishimself. He must know.
post-10323032
Post #126 of 250
elvergun
I hadn't used my 7550s in a while...I put them on today and all I can think is...
...why did I not use my 7550s in a while?
I will not commit this mistake again.
The MDR7550 is a full-size can in IEM size.  The soundstage is soooo wide.
Reactions: ivannnn
post-10323582
Post #127 of 250
kimvictor
Ik. I love the 7550. There is a reason that 7550 is the only universal i ended up keeping, after owning and trying +20 $200+ iems. In fact, once i got the uerm, 7550 was the only iem I wanted to keep. SE535, X20, H200, and FXZ200 all left me. 7550 sounds so full and fun.
Reactions: Sp12er3
post-10338166
Post #128 of 250
elvergun
The 7550 is very underrated around these parts.
post-10449214
Post #129 of 250
TheBoss
Has anyone here tried Shure 315's?
graph wise it looks slightly favorable compared to 7550
post-10449912
Post #130 of 250
kimvictor
Yup. Graph wise, maybe. But not really. SE315, with some reason, sounds like it really really lacks sub bass and treble. I feel like graph doesn't match how it sounds. 7550 is a closer comparison to 535, which I used to own.
Reactions: Sp12er3
post-10450024
Post #131 of 250
TheBoss
What made you let go 7550?  Are you shooting for something higher in the universal IEM realm?
http://www.head-fi.org/t/698038/fs-sony-mdr-7550-iem-16mm-ml-diaphram-driver-aka-mdr-ex800st
For me I think my search for u-IEM is over.  It's either I go c-IEM or get open headphones and related devices need that need to power it.
Reactions: Sp12er3
post-10451513
Post #132 of 250
kimvictor
Well, it was that I used IM03 and UERM too much, and have to time to use 7550. While I do use it once a while, but it's not enough to make me keep it.
Reactions: Sp12er3
post-10451786
Post #133 of 250
elvergun
Did you sell your 7550s?
post-10452775
Post #135 of 250
elvergun
